EM Exhaust (LT) connection ??
Old 03-19-2005, 08:30 PM
Strick
Strick's Avatar
Default EM header (LT) connections ??
I'm ready to jump into these headers. Has anyone installed them with the little high flow cats and connected to the OEM or B&B catback systems? I'd really like a picture of both sides where they connect the collector of the header to the catback. EM's price for these connection pieces seems a little high. I have a 92 LT1 and a 6 speed. Big thanks in advance.
Old 03-19-2005, 09:00 PM
rsafier
rsafier's Avatar
I asked they said that the extensions will not work with B&B 3" system, you would need to get custom pipes made for header->resonator connection.
Old 03-19-2005, 09:02 PM
JB666
JB666's Avatar
I can't answer your question, but I talked to Merle in depth this past week - He's a great guy and willing to go the extra mile for you. Reminded me of Dave from RD. Anyways, my sets on order, and the LTs and hi-flow cats should be to me in the next 2-3 weeks!!!!!!!!!
Old 03-19-2005, 10:26 PM
Perfusion
Perfusion's Avatar
Mine's connected to a Corsa, so I don't know if that's what you're looking for. I've got pics, though, so let me know if you want 'em.
Old 03-19-2005, 10:40 PM
dan6712cc
dan6712cc's Avatar
Here are some pics of the connecting pieces, someone posted these a few weeks ago, cant find the original link:
Old 03-20-2005, 08:26 AM
Strick
Strick's Avatar
You have a PM.
Did you have to cut the corsa pipes going to the resonator to allow room for the high flow cats?
Old 03-20-2005, 08:39 AM
STL94LT1
STL94LT1's Avatar
You will have to shorten and narrow the pipes going to your resonator. Plus have adapters made to connect the 3" collectors/cats to the 2.5" cat-back pipes. I had Midas make these alterations, they charged around ~$130.
FYI: I slid/clamped the cats on to the header collectors.
Old 03-20-2005, 08:54 AM
Strick
Strick's Avatar
Hi Mike,
You could attach the cats directly to the header collector? No bends required? I sure would like to see some pictures of that set up. Thanks
My B&Bs are already 3" going into the resonator.
Old 03-20-2005, 09:26 AM
LT4BUD
LT4BUD's Avatar
I am working right now having a prototype made for connecting a
EM long tubes to 3" B&B with high flow cats.......stand by for more....
Old 03-21-2005, 09:59 AM
LT4BUD
LT4BUD's Avatar
The "prototype" is on the car.....sounds & looks great!!
EM headers to 3" high flow cats to 3" B&B exhaust...
Contact Rottie @ Powerhouse Performance for more info..
rottwild@adelphia.net
or 440-796-3169
Old 03-21-2005, 10:18 AM
Strick
Strick's Avatar
or 440-796-3169
Any chance of a few pictures?
Old 03-21-2005, 10:24 AM
FoolCrzy
FoolCrzy's Avatar
Old 03-21-2005, 10:58 AM
tjwong
Support Corvetteforum!
tjwong's Avatar
Doing a EM to B&B connection is a peice of cake. I did my own with some 3" SS tubing:
I moved my cats to the tunnel area as I have a 6 speed which for me made it easier. Some have placed them directly behind the collectors which is also a good place.
The drivers side tube needs to be extended about 6" and the passenger side about 16". I had a local muffler shop swage the ends of the tubing for a tight slip fit over the EM collectors. The other end over the B&B tubes were also a slip fit which once in place are welded. The CATs are slip fit to the B&B tubing and just clamped using band clamps.
Old 03-21-2005, 12:58 PM
LT4BUD
LT4BUD's Avatar
TJ's setup looks great, but for x-pipe not resonator...
Old 03-21-2005, 01:09 PM
Timmy!
Timmy!'s Avatar
Would that setup work on an auto? Looks like the cats would hit the tranny. I still haven't heard about a true dual setup with cats on on auto without problems.
Old 03-21-2005, 01:16 PM
sothpaw2
sothpaw2's Avatar
Any body know if performance-wise it is best to mount the cats close to the header collector or closer to the resonator?
My guess is collector but I wonder what others think/have tested/tried.
Old 03-21-2005, 03:44 PM
Lichen
Lichen's Avatar
The cats are placed behind the tranny. I have the EM longtubes, RT cats and 3" B&B.
To EM Exhaust (LT) connection ??
Old 03-21-2005, 03:51 PM
Timmy!
Timmy!'s Avatar
Nice! So no resonator then? Looks like that is a vert with the factory x-brace in there too?
Old 03-21-2005, 04:05 PM
Lichen
Lichen's Avatar
It's a '93 vert and yes I have the resonator, I just don't have a picture that shows the entire setup.
Old 03-21-2005, 06:19 PM
Strick
Strick's Avatar
Thanks guys for the photos. Now I think this is doable.
Quick Reply: EM Exhaust (LT) connection ??
