Can I check the EGR this way?
..if I just pull the vacuum line off of it - wouldn't this close the valve if it happened to be open? How can I be sure?
Sure it will close, if it was open. It is suppose to be open only during part throttle crusing conditions.
If is sitting there idleing, it should be closed. I don't recommend running along side while you try and unplug it, but you are welcome to try.
A simple test is
I test mine with the motor off first. Apply vaccuum to the EGR by pumping the line down. (Or just attach a line and suck on it.) Make sure it holds vaccuum until you release it. I had one that you could pull open and it leaked closed and set codes.
I had one that was opening too far, too soon. The return spring was weak, but still worked. It caused a lean misfire, at cruise. This isn't as easy to test for. The vacuum pump will only tell you if it opens and closes.
RACE ON!!!
RACE ON!!!
Originally Posted by CentralCoaster
At idle, exhaust backpressure bleeds of the vacuum to it and keeps it shut.
RACE ON!!!
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by CFI-EFI
At idle, the ECM shuts off the vacuum supply via the solenoid.
RACE ON!!!
RACE ON!!!
See, we're both right.
yes, but it doesn't open it to atmosphere. so the line will still hold vacuuum and hold the egr open. that's what the bleed valve is for.
RACE ON!!!
i don't know if this is the same with the L98 (again) but the LT1's valve diaphram has a tiny hole to bleed off the vacuum. mayhaps that's what CentralCoaster's talking about.
back to the original question i agree with CFI that a vacuum pump will show you a faulty valve (at least if it holds vacuum) pretty easily.
hey CFI, how did you figure out the lean misfire problem? the valve still held vacuum, right?
You can either use a little mityvac to check it or just put a piece of vacuume line on it and suck on it with your mouth and see if it holds vacuume. You just want to make sure your diaphram isn't busted or leaking.
RACE ON!!!
