price on gear install
Old 02-18-2005, 04:33 PM
6spd
6spd's Avatar
Default price on gear install
i got a price of $695 from my corvette shop. that's labor i have to by the parts. good or bad??
Old 02-18-2005, 04:39 PM
rocco16
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
The going price in my area is around $1200 for the complete job.
I drive the car in, drive the car away....
Larry
code5coupe
Old 02-18-2005, 06:45 PM
CFI-EFI
CFI-EFI's Avatar
Who's pulling the drop in? If it's you, that waaaaay high. If it's not, it ought to be. Labor to set gears generally runs from $150.00 to $250.00, depending on what he thinks his time is worth and his degree of comfort with the job.
RACE ON!!!
Old 02-18-2005, 07:01 PM
ar91c4
ar91c4's Avatar
RACE ON!!!
100-150...
Old 02-18-2005, 07:16 PM
TM-Z06
TM-Z06's Avatar
I paid $650 ---- that was for gears and labor.
Old 02-18-2005, 08:08 PM
6spd
6spd's Avatar
am buying gears what else should i buy?? also they are pulling the rear and doing the change.
Old 02-18-2005, 08:15 PM
CFI-EFI
CFI-EFI's Avatar
Depending on the mileage, bearings and a new set of posi clutches can be a good idea. You can save much more than half that labor charge if you drop it yourself. OH! Don't forget to swap out the speedo gears.
RACE ON!!!
Old 02-18-2005, 08:25 PM
6spd
6spd's Avatar
thought about that but i just don't have the time. i have 80,000 miles.
Old 02-18-2005, 08:49 PM
LD85
LD85's Avatar
I pulled my rear in @ 2-hours, quite an easy project actually. And put in the Poly bushings while I was at it. ($50)
I dropped off the Dana 44 and paid $150 for the gear install, and $110 for a set of low mileage 3.45's.
Old 02-19-2005, 12:29 AM
tjwong
Support Corvetteforum!
tjwong's Avatar
Call Randys Ring and Pinion. You should get a master installation kit. It comes with all the bearings, shims, ring gear bolts, pinion nut and seals that one will need to install the gear set. It even comes with gear marking compound to paint the gears with so that the installer can see what the pattern is after the installation. Cost for a D44 install kit is roughly $100 plus shipping.
To price on gear install
Quick Reply: price on gear install
