Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-15-2005, 12:18 PM   #1
hz900
CF Senior Member
hz900's Avatar
Default How to replace ball joint boot?
Both the upper ball joint boots are torn on my project car and need replacing so grease doesn't get all over the supspension pieces I just polished (PITA).
Anyway is there a way to replace the boots without damaging and replacing the ball joints because they still appear to be good and after checking the price on these ball joints I'd rather not replace if I don't have to.
hz900 is offline   Reply With Quote
Old 02-15-2005, 12:21 PM   #2
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Got pics of the suspension?
CentralCoaster is offline   Reply With Quote
Old 02-15-2005, 12:36 PM   #3
brookman
CF Senior Member
brookman's Avatar
Yes there is - if you can find the tool that fits. it kind of looks like a horseshoe with a bolt through the center. This is actually a pitman arm puller - http://www.toolrage.com/prodView.asp?idproduct=2451
I have also used a small gear puller. Make sure you back the nut off - just until there are no threads exposed - in case the bolt slips.
I found this - but have never used it.
http://www.sjdiscounttools.com/ta61900.html
I would definately avoid the picklefork method.
brookman is offline   Reply With Quote
Old 02-15-2005, 12:47 PM   #4
hz900
CF Senior Member
hz900's Avatar
Quote:
I'm redoing the whole car, got the front tore down to the frame rails to clean and paint. I'm taking pics along the way and will post the whole project when I'm done probably this summer. If I get a chance I might post some individual pics of the suspension for ya though, although I haven't uploaded them yet so it might be a little bit.
Old 02-15-2005, 03:22 PM   #5
mean8t
CF Senior Member
mean8t's Avatar
Energy suspension makes a nice poly kit to replace all the boots on the ball joints and tie rod ends. Not bad price replace all of 'um while you are in there.
mean8t is offline   Reply With Quote
Old 02-15-2005, 03:59 PM   #6
hz900
CF Senior Member
hz900's Avatar
Quote:
yeah I know I am looking at that kit. Just want to know how to replace. They don't just simply slip over do they? I thought you had to take the ball joint out to replace the boot, or am I mistaken.
Old 02-15-2005, 04:33 PM   #7
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
You do not have to press the joint out. They do just slip over. I don't recall the details on the vette as it's been a while since I did it. It was either this car or my Accord where the original boots were held on with some retainers that were a PITA to get off. Other than that no problems.
Vis Croceus is offline   Reply With Quote
Old 02-18-2005, 03:32 PM   #8
boatman
CF Senior Member
boatman's Avatar
Default Ball Joint Boots
Sent you e mail. If you find out, or have the address where I can get boot replacement's, please let me know. I have one that is shot.
Thanks,
Boatman
Sunny south FL
boatman is offline   Reply With Quote
Reload this Page How to replace ball joint boot?
Tags
84, ball, boot, c4, c5, change, corvette, cover, dust, forum, joint, joints, replace, replacing, upper
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
