Engine Problem
Old 02-08-2005, 09:01 PM
ETHYL
ETHYL's Avatar
Default Engine Problem
While stopped for a traffic light, and transmission in DR, the engine starts to miss, then return to normal after a few seconds. It keeps doing this on and off until I drive off. Do not feel this problem on acceleration or cruising.
Anyone ever experience this problem and found the cause. I have 94000 miles. Plugs and wires were replaced at about 70000 miles.
94 Coupe AT
Old 02-09-2005, 02:48 AM
85 500 horse
85 500 horse's Avatar
The first thing I'd do is check the timing. It sounds like when the car is coming to a stop, the timing is being retarded too much that it begins to sputter and when you accelerate, the timing advances and corrects itself.
Old 02-09-2005, 09:59 AM
jay007
jay007's Avatar
What year is the car. remeber u cant set timing on LT1's
Old 02-09-2005, 10:55 AM
MikeC4
MikeC4's Avatar
94 Coupe AT
I think you would be better off pulling your error codes. You may have an O2 sensor that is acting up, a bad TPS or IAC. Anyway, pull your error codes. The '94 has Optispark and timing is a non-adjustable feature of this miracle ignition system....
Old 02-10-2005, 02:04 AM
85 500 horse
That sucks. Another GM wonderful invention.
To Engine Problem
Quick Reply: Engine Problem
