Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-24-2005, 12:40 PM   #1
RWDsmoke
CF Senior Member
Default ECM Help
Hello everyone, I'm new to Corvettes and this site but not to EFI and prom burning. I put a SD TPI in my s-10 7 years and 120k miles ago and I know it well. I just bought my first Corvette, a 1986 with no motor and a harness that has some missing wires. Here's my plan, please tell me if I'm on the right track. I want to convert to SD because I know it and have a laptop and a prom burner. (and dont want to spend the money for the MAF parts) I also have a new 355 vortec motor in my garage, Ballanced, Summit engine kit in it, GM hotcam, heads have been machined for bigger valve springs and higher lift. I modified an Lt4 intake to fit the vortec bolt patern and the other mods from lt1 intake.com website.
Can I use a 7730 ecm, get the wiring harness from a SD v6 Camero (cheap and easy to find) use the ecm connectors and whatever extra wires I need from the v6 harness. And using the diagram from my 91 Camero TPI factory service manual? I also have access to a 87 corvette factory service manual, is it the same as the 86? And last, which memcal do I need? Are all 7730 350 memcals the same except for the bin? Thanks for the help.
RWDsmoke is offline   Reply With Quote
Old 01-24-2005, 02:30 PM   #2
DOCTOR J
CF Senior Member
FYI
There was quite a bit of traffic on this board a couple of years ago re 165 -> 730 conversions. Do
a search here on "730" or "730 club" for details of the swap. There are some minor differences
between Camaro & Corvette ECM pinouts, including a pin for the Oil TS & whether some switches
are NO or NC. Nothing too major, IIRC. Seems to me there is also quite a bit of descriptive swap
info on the TGO prom board too.
The 165 memcals use a 128K prom; 730 memcals are set up for 256K.
To be on the safe side (with the resistor array) I'd get a CalPac that matches the mask you plan
to run - then there will be no surprises WRT 'limp home' operation.
If it's a daily-driver, I'm not a big fan of the HotCam.
DOCTOR J is offline   Reply With Quote
Old 01-24-2005, 02:34 PM   #3
DOCTOR J
CF Senior Member
FYI
Old 01-24-2005, 02:37 PM   #4
DOCTOR J
CF Senior Member
FYI
Search here on "730" or "730 club" for details of the swap. There are some minor differences
Reload this Page ECM Help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Forum ECM-PCM Tuning Section FAQ Marcho Polo C4 Scan & Tune 141 05-18-2011 11:42 AM
Aldl Obd1 Diagostic Help!!!!! jerrys 1989 C4 Scan & Tune 22 10-01-2005 07:28 PM
i think dealer is trying to stiff me!! NEED HELP ASAP wannabe-psi C5 Tech 44 06-07-2005 01:46 PM
ARGG! My car started on fire! Help. rsafier C4 Tech/Performance 68 04-14-2004 06:08 PM
Professional Grade Help Needed!!! akhdnh C4 Forced Induction/Nitrous 29 06-22-2003 04:26 PM
Need ECM help for idle problem. Mike263 C4 Scan & Tune 10 05-13-2002 09:58 PM
ECM/PCM Tuning Section.... yeah or nay? Marcho Polo C4 Tech/Performance 77 12-16-2001 12:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
