01-23-2005, 01:39 PM
CF Senior Member
Suggest putting a scanner on the ALDL port. There are only about 3 signals coming from the engine bay
that affect idle RPM:
1. If the CTS reading is -40 at start-up, you've open-circuited the CTS thermocouple. Repair or replace.
2. If the 5-wire(?) connector at the distrib is hosed, ECM will (perhaps) see an erroneous RPM signal.
Replace the wiring pigtail.
3. If the IAC motor or connector is hosed (or if you created an intake vacuum leak) the ECM will be unable to
maintain the idle speed set-point. That will be apparent from the ALDL datastream.
HTH
