Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-14-2005, 11:08 AM   #1
jeepie91
CF Senior Member
jeepie91's Avatar
Default Datamaster Results ?
My car has had a small miss since I got it and over the last couple years have change many parts, some for this reason, some for other reasons. The miss is still there, I just setup and made a couple datamaster runs since this is my first experience with scan tools I am trying to figure out which values are good and which could be problems. For example at idle I noticed that a few of the readings are jumping all over the place, O2 volts is from 85 to 900 mv, spark advance is from 15 to 25, which seem to strange to me since the car is at idle. Does anyone have a good datamaster file that I can look at to compare to mine. The car is a 91 auto it has about 45k on it, it is pretty much stock. Please let me know if you any other info.
Thanks.
jeepie91 is offline   Reply With Quote
Old 01-14-2005, 11:52 AM   #2
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
Thanks.
It is normal for the o2 voltage to fluctuate from low to high. This means that the sensor is working properly and that the ECM can know that it can go to closed loop. At idle I don't think that your timing should be bouncing around that much. If you want you can email me your datalog file and I can take a peek at it.
tjwong@qwest.net
tjwong is offline   Reply With Quote
Old 01-14-2005, 03:05 PM   #3
jeepie91
CF Senior Member
jeepie91's Avatar
Thanks a bunch, the files are on the way.
Reload this Page Datamaster Results ?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dyno results & Questions - long !! 1MoorTym C4 Tech/Performance 15 11-16-2004 09:25 PM
Dyno Results, miss and all 96GS#007 C4 Tech/Performance 24 03-15-2004 07:14 PM
LT4 Dyno Results GlockLT4 C4 Tech/Performance 14 07-22-2003 03:10 AM
Went to the track, dissapointing results! Squareseven C4 Tech/Performance 25 04-27-2003 01:15 PM
Guess the results of tomorrow's injector test! Nathan Plemons C4 Tech/Performance 46 11-08-2002 09:59 PM
Eratic power curve results from Dyno. Need some advice on how to fix it. UB2 SLOW C4 Tech/Performance 23 09-24-2002 12:55 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
