Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-14-2005, 03:51 AM   #1
nocturnalsilence
CF Member
nocturnalsilence's Avatar
Default Finally done with 6 spd swap. time for injectors
I am finally done with my 6 speed swap but now it is time to install my 30 lb svo injectors. Does anyone know where I can find a table with the values I need to change my program to. Thanks
Dave
nocturnalsilence is offline   Reply With Quote
Old 01-14-2005, 11:49 AM   #2
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
Dave
Dave you should just change the injector size constant to reflect the size of your new injectors. Also remember that the SVO injectors are rated at 37 PSI and not 43.5 as the GM fuel rail rating. To calculate the correct flow the formula would be:
( SQRT new pressure / old pressure ) * old flow rate
( SQRT 43.5 / 37 ) = 1.084
1.084 * 30 = 32.52
Also I would use the original injector offsets that are in your PCM now. Contrary to beleif its not always wise just to change those settings without first see where your fuel trims are.
I would make the injector size constant change to 32.5 lbs/hr then run the car and datalog it. If you see that the fuel trims are off to one side or the other then make the injector offset change. In most cases I have found that it isn't necessary to mess with them at all. Especially in cases where the engine has a new lumpy cam, skewed fuel trims can be caused by other changes.
tjwong is online now   Reply With Quote
Reload this Page Finally done with 6 spd swap. time for injectors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
