Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2005, 05:32 PM   #1
Thomas1
CF Member
Default Need ASR help
Hello, I posted awhile back. I have not had luck with this issue. I cannot get my ASR to turn off. I have a 95LT1 coupe. I checked the fuse panel, all ok. checked fuse 27 I belive. How do I go about tracking down why it won't turn off? Is there something common to check? Any help would be appreciated. I have a Haynes manual, but it is pretty useless.
Thomas1 is offline   Reply With Quote
Old 01-17-2005, 04:05 AM   #2
want1
Junior Member
im no vette expert but its the same set up as an f-body than i can prolly help. those switches go out alot. mine has been replaced twice already. to track down something like that, see if you have power to the switch.if so whats the voltage drop there, or you could do a availible voltage reading. see what that is and compare it to the manufactors spec. if the reading comes back fine then i would almost guarantee its the switch. hope that i was of some help.
....before you do anything get a wiring diagram, find the wire you need then start.
want1 is offline   Reply With Quote
Reload this Page Need ASR help
Tags
1994, asr, circuit, corvette, schematic
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I need urgent help. Andrade108 C5 Tech 18 03-25-2004 05:23 PM
CRAP, I need some help with this one! 212mike C5 Tech 16 08-27-2003 07:35 PM
Wasn't the OPTI :( Need further HELP PLEASE keekster C4 Tech/Performance 46 10-25-2002 11:05 PM
Need some help. Show's sys on my dash and runs bad Cooteredd C4 Tech/Performance 11 03-03-2002 05:24 PM
ASR help! BAdAzZV8 C4 Tech/Performance 16 02-07-2002 02:03 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
