Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-12-2005, 01:07 PM   #1
flyersfan1088
CF Senior Member
flyersfan1088's Avatar
Location: What did the 5 fingers say to the face? SLAP!!
Default Who sells blank PROMS?
I need to get a hold of a blank PROM to send to Jesse so I don't have to send mine out. Does anybody have, or know where I can get a PROM. It needs to fit an '86 ECM. Thanks
flyersfan1088 is offline   Reply With Quote
Old 01-12-2005, 01:16 PM   #2
Red Tornado
CF Senior Member
Red Tornado's Avatar
Call http://www.superchevyperformance.com/ tell them you're a corvetteforum.com member, should be about $50.....Give them the year, final drive ratio, and last 8 digits of your VIN.
Red Tornado is offline   Reply With Quote
Old 01-14-2005, 10:27 PM   #3
SBNova
CF Senior Member
SBNova's Avatar
The above is for the memcal, if you want just the eprom, go to futurlec.com. You want a 27c128, but a 27c256 will also work just fine. Even better, is the 29c256- which is electronically eraseable. The first two are probably $2-3 each, and the 29c256 is around $4-5 I think. Shipping from this company is slow though.
Futurlec has the 27x256's for $1.80, and the 29C256's for $4.50 each
SBNova is offline   Reply With Quote
Old 01-16-2005, 12:12 AM   #4
Muffin
CF Senior Member
Muffin's Avatar
Try Craig Moates at moates.net. 29c256 for $6.00 a copy.
Muffin is offline   Reply With Quote
Old 01-16-2005, 03:10 PM   #5
scorp508
CF Senior Member
scorp508's Avatar
http://www.moates.net/product_info.p...products_id=38
scorp508 is offline   Reply With Quote
Old 01-17-2005, 08:10 PM   #6
flyersfan1088
CF Senior Member
Thanks guys. I've got another question. When Jesse did my chip the first time, I sent the Mem-cal. How difficult is it to install the reprogrammed chip in the Mem-cal> Would a Mem-cal out of an F-Body work, since it's going to be reprogrammed anyway? I figure those should be easy to find in any salvage yard.
Old 01-17-2005, 10:12 PM   #7
SBNova
CF Senior Member
SBNova's Avatar
The memcal from an F-body will work as long as its from an 86-89 with a V-8 and a TPI. But, the 86-88 use a cold start injector, and the 89 doesnt- meaning that the 89 memcal (with the factory 89 prom) will overly enrich the engine when starting cold, unless you unplug the ninth injector (easy to do). When you burn the chip (or have it burned) for your 86 with a cold start injector- it will then work just fine in the 89 memcal, with your ninth injector plugged back in.
The best way is to buy the Moates adapter with a ZIF socket, and use a new eprom, while keeping your stock memcal unaltered. Or, buy a zif and carefully solder it to a junkyard memcal, and get a new eprom.
Old 01-18-2005, 10:55 AM   #8
comp
CF Senior Member
comp's Avatar
Quote:
6 buck's
comp is offline   Reply With Quote
Old 01-18-2005, 06:15 PM   #9
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Folks you could also try a company called Digi-key www.digikey.com it looks like they run about 6.75 ea. for the 28 pin dips. They have PLCC's too.
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 01-19-2005, 06:19 PM   #10
Muffin
CF Senior Member
Muffin's Avatar
Quote:
Originally Posted by comp
6 buck's
comp,I missed your point. Craig has them for $6.00 each.
Old 01-19-2005, 11:19 PM   #11
scorp508
CF Senior Member
scorp508's Avatar
6 buck's
Your point equals?
Old 01-21-2005, 11:09 AM   #12
comp
CF Senior Member
comp's Avatar
cheap heard Highrt price's,,, simple point
Old 01-21-2005, 11:10 AM   #13
comp
CF Senior Member
comp's Avatar
cheap heard Higher price's,,, simple point
Old 01-21-2005, 11:10 AM   #14
comp
CF Senior Member
comp's Avatar
WTF
Old 01-22-2005, 02:29 PM   #15
Muffin
CF Senior Member
Muffin's Avatar
Oh!
Reload this Page Who sells blank PROMS?
Tags
blank, proms
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
