Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-11-2005, 06:55 PM   #1
Red Tornado
CF Senior Member
Red Tornado's Avatar
Default L98 Chips & SD vs. MAF: For Chip Is It Easier to Recalibrate?
wanted to ask the tuning gurus who successfully burn chips with Speed Density and MAF systems.......Is the SD system ECM chip easier to tune, or the MAF?
Red Tornado is offline   Reply With Quote
Old 01-11-2005, 11:49 PM   #2
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
As far as the physical aspects of programing, both are the same to do. However a MAF control strategy is much more forgiving to tune than a Speed Density strategy. You have to do a lot more dataloging and make many more changes to the VE maps with a SD system before you can call it done. When one changes a cam in a SD strategy one basically will have to remap the VE tables. There are tools to help with doing this based on scan readings. One such tool is VE Master for the $8D mask. Using either Datamaster or Diacom one datalogs for several minutes in the problem areas, then using VE Master a new bin file is iterated using mathmatical calculations to change the VE tables in the BIN file. Using a load bearing chassis dyno helps immensely when tuning SD controlled cars, with such a dyno the engine can be loaded at a given RPM or speed for the tuner to make his VE adjustments.
tjwong is offline   Reply With Quote
Old 01-12-2005, 01:18 PM   #3
Red Tornado
CF Senior Member
Tom, thanks. That's just what I'll do.....local dyno & get the .bin file based on the results, for evaluation.
Reload this Page L98 Chips & SD vs. MAF: For Chip Is It Easier to Recalibrate?
Tags
chips, l98
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
