Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-29-2004, 05:37 AM   #1
Hawaiian Punch
CF Senior Member
Hawaiian Punch's Avatar
Send a message via AIM to Hawaiian Punch Send a message via MSN to Hawaiian Punch Send a message via Yahoo to Hawaiian Punch
Default I hope you can help me out here.
a starter tune info for a L-98 with the hotcam installed so I can burn it on a chip and have a good base to start on with my tuning please?
Hawaiian Punch is offline   Reply With Quote
Old 12-30-2004, 01:10 PM   #2
Ramanstud
CF Senior Member
Ramanstud's Avatar
Send a message via AIM to Ramanstud
Man, I know you're looking for some help but I guess none of us has anything....
I would recommend making one chip that stays in Open loop (set the Minimum Coolant Temp for CL really high), then add maybe 10% fuel in the higher LV8 values (say LV8's 80-100 and up to spare idle). Then take the car out and do progressively faster accelerations until you either see a drop in O2 readings or knock. Then adjust accordingly (add more fuel until O2 volts are ~900ms) and work up to WOT runs. If still knock and you know it's getting plenty of fuel, then start to reduce timing in affected areas. After that, you can worry about idle, PE and part throttle stuff.
Others may have different ideas, but that should get you on the right track and give you a baseline- and your tables may look different depending on the ECM and mask. But basically increase the Open loop vs load tables by an appropriate amount, and then see how close you are by datalogging. Because every engine is different, I doubt too many people will have BINs they want to send you (and honestly, you probably don't want some butchered BIN anyway). But I'll help you any way I can with what little I know about tuning.
Ramanstud is offline   Reply With Quote
Old 12-30-2004, 02:43 PM   #3
Hawaiian Punch
CF Senior Member
Thanks Ramanstud for replying, if the fuel is high, how would I go about bringing it down? what areas should I go in oder to do this?
I stuck a hot cam in the car and so now the MAP is reading that the throttlebody is more open then it really is cause of the lose of presure in the plenum I would guess, so now it's dumping in lot's of fuel.
Old 12-30-2004, 04:14 PM   #4
Ramanstud
CF Senior Member
Ramanstud's Avatar
honestly, all of my tuning is on MAF cars, so I can't give specifics with the SD systems. This could be more complicated than you might think, so I don't want to throw out blind suggestions. If you go over to thirdgen.org and log in, their archived posts and DIY Tuning boards are top-notch. there's a ton of SD stuff over there to read.
Old 12-31-2004, 03:43 AM   #5
Hawaiian Punch
CF Senior Member
Cool!! mahalo once again for your reply and much needed help, I'll go over there and check it out.
Old 12-31-2004, 12:16 PM   #6
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Punch Check your Mail
-=Jeff=- is online now   Reply With Quote
Old 12-31-2004, 04:42 PM   #7
Z06_BluByU
CF Senior Member
Z06_BluByU's Avatar
I had my share of trouble with Speed Density.. but once you ge the hang of it it isnt to bad..
To help you tune your fuel map I recommend getting VEmaster (its a program that can read your datamaster datalog files and adjust your fuel map tables in your .bin file accordingly... as for spark.. I know you probably can add a bit more in the 80kpa-100kpa range in the low rpms and take a few degrees out in the upper rpms.. but I'm sure someone else already has some of these tables for the L98 mapped out.. good luck
Z06_BluByU is offline   Reply With Quote
Old 12-31-2004, 08:33 PM   #8
-=Jeff=-
CF Senior Member
-=Jeff=-'s Avatar
Datamaster will not work for Ease scan files.. However, i made a similar program to VEMaster that I use on my Car.. It is also not limited to the same ceiling as VEMaster. the BLMs are now 128 +/-4
Punch,
Send the bin you used for scanning along with the Ease scan file and I will run it through my program.
Jeff
Reload this Page OK, I'm gonna try asking this once more, I hope you can help me out here.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
