12-29-2004, 02:57 PM
CF Senior Member
ECM will compensate some, but for optimum performance, a chip designed for the larger injectors is needed. Just so happens that my car is an 88 with SVO 24# injectors. Constant in stock chip is 22, but I hade to set mine at ~26.25 to get my fueling correct. The Ford injectors are rated at a lower FP than we use.
If you want to spend a few bucks for the moates adapter and chip, I'll gladly burn you my tune which also adds some timing and I can turn your fan on at whatever temp you want.
