Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-21-2004, 08:23 PM   #1
MDGaumond
CF Senior Member
MDGaumond's Avatar
Default This thing just won't idle
I am hoping that someone out there can help me. I have a 1986 vert with a new mild mod TPI engine with auto trans. I put the top down Saturday and took a ride through the canyons. It ran great and I loved it, purred like a kitten. I got up Sunday and it wouldn't idle. If I hold the gas pedal down a bit it will idle (700 RPM) but when I let go it stalls immediately. I can't figure out what's going on. I haven't changed anything rom Saturday, heck it's even the same tank of gas. Does anyone have any ideas? Is there an idle adjustment screw or something? I can't find one. Please help.
Thanks and Merry Christmas to everyone!
MDGaumond is offline   Reply With Quote
Old 12-22-2004, 02:32 AM   #2
ol,RJ
CF Senior Member
ol,RJ's Avatar
its probably just time to clean the throttle body (kinda a maintainance thing).
just remove the intake hose, hold the throttle open, and wipe behind the throttle with a rag soaked with carb cleaner.
the carbon build up back there can effect idle quality.
If that doesn't help then you may have a sticking IAC valve.
ol,RJ is offline   Reply With Quote
Old 12-22-2004, 12:45 PM   #3
MDGaumond
CF Senior Member
MDGaumond's Avatar
Default Thank You I'll Try It
Old 12-22-2004, 01:00 PM   #4
gbody5
CF Senior Member
gbody5's Avatar
Be sure to use Throttle Body cleaner, safe for coated surfaces, some carb cleaners will eat away the finish.
gbody5 is offline   Reply With Quote
Old 12-28-2004, 06:23 AM   #5
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
Do not touch the idle screw.I would check the EGR valve or check codes to see if you have a 34.
It was ok the night before. Also check the vaccum line at the back of
the distributor it's a 3 way vac bulb.
Check the gas cap see if it is on tight.
REDC4CORVETTE is offline   Reply With Quote
Reload this Page This thing just won't idle
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tired of throwing parts at this thing - unsolved - running waaaay rich at idle... Daniel DK C4 Tech/Performance 18 10-17-2003 11:19 AM
My '95 STILL won't idle! HELP JayH C4 Tech/Performance 33 12-15-2002 03:44 AM
Won't start/idle -- Ideas? I have data K87ZZ4 C4 Scan & Tune 16 09-30-2002 04:12 AM
Won't start or idle K87ZZ4 C4 Tech/Performance 19 09-26-2002 03:31 PM
86 won't idle okinawa86vette C4 Tech/Performance 12 09-22-2002 03:02 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
