Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-19-2004, 10:04 AM   #1
darkman5001
CF Senior Member
darkman5001's Avatar
Send a message via AIM to darkman5001 Send a message via MSN to darkman5001 Send a message via Yahoo to darkman5001
Default $6E update for 86 memcal...
How can I find out if I have the $6E prom for my 86? I can't datalog at 8192, only 160 mode. What exactly do I need to upgrade to the $6E so I can datalog in 8192 mode? Thanks!
__________________
Hooker Super Competition Longtubes & Hooker Y-Pipe /w Jet-Hot, Random Tech Cat, Magnaflow Catback, FMS 24# Injectors, Holley AFPR, 52mm GM Throttle /w Bore-Matched Air Foil by Dave Koldos, chip done by Ski_Dwn_it, Summit Racing Mini Starter, 700R4 /w TransGo, Oversized Billet Aluminum 2-4 and 4th gear servos, Oversized boost and int/rev boost valves, 9.5" 2800 Vigilante TC, 3.07 gears
Proud U.S. Air Force Airman!
darkman5001 is offline   Reply With Quote
Old 12-19-2004, 02:17 PM   #2
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
The only way I can do it is to read your prom and try to open it with a $6E definition. If TC tells me its a 32 then we know otherwise
tjwong is offline   Reply With Quote
Old 12-19-2004, 10:34 PM   #3
darkman5001
CF Senior Member
Quote:
How do you read the chip? Does chip have to come out of car?
__________________
Old 12-19-2004, 11:05 PM   #4
tjwong
CF Senior Member
tjwong's Avatar
I have to have the prom, plug it into my prom programmer and read it. Then I attempt to open the file with my Tuner Cat program with the $6E or the $32 definition files. One or the other would open it, if its wrong I get a warning message from the software. If you need, you can send it to me with prepaid return postage and I will read it and let you know what you have, and return it. I can do this on the same day as I receive it, and of course this would be done as a courtesy to a fellow forum member
Reload this Page $6E update for 86 memcal...
Tags
32, 6e, 86, cal, definition, mem, memcal, upgraded, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
