Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-18-2004, 11:47 PM   #1
red L98
CF Senior Member
red L98's Avatar
Send a message via AIM to red L98
Default help with timing please
Hey guys
I plan on taking the car to the dyno this week and spraying the car.
The only problem is I have no idea what my WOT timing is and I don’t feel safe spraying the car. The tuning was done by Jesse ski_dwn_it and the car runs great with the tune.
The base timing is set at 8* at 1000 RPM with the ECS not connected at 25* with it connected. When you connect the ECS does that show you the total advance
See on none computer car to set the total timing you just rev the car up to 2500 PRM and it shows you the total timing. Or is the total timing programmed in the chip
I was told to be safe you have to set the WOT timing at no more than 30* with nitrous. Its only a 150 shot what do you guys think I should set it at. I run 110 fuel in the nitrous cell and 100 in the cars tank.
red L98 is offline   Reply With Quote
Old 12-28-2004, 07:17 AM   #2
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
You need 1 1/2 degrees for each 50 hp with 150 that would be 4 1/2 degrees retard.
Total timing should be 28 to 30 degrees at 3000 rpm.
but that is with about 106 octain I think you can put more lead in with a 110 oct.
If she flattens out kill it when you hit the juice, many dynos have blown a motor due to the long lag between shifts .
REDC4CORVETTE is offline   Reply With Quote
Reload this Page help with timing please
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
new 427ci trouble with idle ..please help Tomulrich C5 Tech 15 02-18-2005 03:13 PM
LS1 Edit changes to help with Cam surge?? Brian@KelleyPerf C5 Scan & Tune 12 07-22-2003 12:06 PM
Help With Timing Please! bence13_33 C3 Tech/Performance 35 04-24-2003 12:28 AM
I need to kill this Gremlin, can you help with timing? coda C3 Tech/Performance 12 07-22-2002 03:47 PM
Crap!!! need help with an oil leak mn_vette C4 Tech/Performance 23 04-05-2002 12:30 PM
High IAC counts (128~160), can't get it down with timing/idle, ideas? C4 Tech/Performance 17 03-13-2002 02:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
