Quote:
Originally Posted by mos90
the hotcam doesnt like much more that 36*. i ran mine at 36* and it ran faster that at 34*. but ever car is different. what advance is programmed in the chip? i would rather keep my base a 6* and change the wot timing in the chip then do global changes with the distributor.
I'm waiting for a scan, being here in Hawaii it's not readyly avaliable to us out here as far as chip tuning, I have a TPIS chip right now for the mods I had before the cam install a few day's ago, my car seems to run way better with the timing is set at 8* top (crank) then @ 6*, seem normal to you and/or is this one of those case's were each car is different? I ca't set it @ totel timing cause I have the old fashin timing light, so I can't set it like the new ones.
Thanks for your help.
Kalani.
