thank heavens,,it was the freeking ecm,,found one on ebay,,hard to find,,,trouble all gone,,,,
Let me know if it works long term. I replaced my ECM when i had the same problems and symptoms as you experienced and it worked for a month or so then the problems returned.
I can get around the problem because i noticed the check ASR light stays on when it put key in warning me of a no start when hot. i just re- insert key a few times until I don't see the ASR light and it fires right up.
__________________
Dream Well. It may come true.
Only thing harder than achieving excellence is maintaining it.
2005 MagRed Corvette
1992 Polo Green Corvette
Just joined the forum today. Hope its okay to jump in. Have a 91 L98 Black Vette. Have a simular problem. Starts up quick. 30 miles down the road and turn her off and a little later, it's hard to start. Kinda like the starter drags.
It started after I put a Hypertech Thermo Master Power Chip in the ECM. Also after I put a Vortex Rammer cold air system with a 160 degree thermostat.
Hi,Im new to this great forum,hope you'll help me too
I also have SECURITY light flashing,
But my engine has problems only when its cold,
Any body have an idea?
What about "check engine" light?? how can I trn it off (w/out disconnect the bulb )?
you dont disconnect the bulb that is telling you there is something wrong take it to a pro and get it checked
Did anyone come to the idea, that it might be the EGR vavle. If it's stuck the engine won't breath and will stall, because it gives a different reading or vac. to EGR solinoid. If the ECM get's it's incorrect signal then the gas's and carbon's will be off and interupting the fuel system...ideal, clean your EGR valve by activating diaphram up and down manually by hand, or replace.
Had a hot start problem w/ my '76- Started & ran great when engine was cool- Stop for a couple of minutes & it would grind but not start-Thought it was a starter problem & changed out 20 or more (I'm a slow learner) before I stumbled on the timing being too advanced- It ran great but after the engine warmed , it wouldn't restart- Don't know if this is your problem but sometimes its the simple stuff
