Hey, Mo!
When did you put on the coil-overs? How are they working out for you? I can't recall if you
had those the last time we talked or not...
I don't see any major problem with estimating power based on airflow. My only point above was
that BSFC numbers are (AFAIK) based on equilibrium conditions, and you need to take them with a
grain of salt on a short-duration acceleration test.
I spent a few weeks chasing that line of thought myself, until I realized a (N/A) small-block is
only burning ~1 oz. of fuel/sec @ 6,000 RPM. Trying to decide if a test had used 1.5 or 2.0 ounces of
gas had me going cross-eyed. After slapping myself in the head a few times I decided it was better
to use kinetic energy to measure transients. My reasoning was that, based on my instrumentation,
it's easier to find an extra 100,000 ft lbs of energy than 0.25 ounces of fuel :). That gives me enough
repeatability between tests so I have at least one metric to evaluate engine & programming changes.
By way of background on the complexity of the fuel balance, there's an SAE paper here that
speaks a little to injector compensation, wall wetting, air flow and such - although it's more about
cold-start than power enrichment:
http://www.delphi.com/pdf/sae/1999-01-0553.PDF
There is another Delphi paper which deals with MAF accuracy & transfer functions -
http://www.delphi.com/pdf/techpapers/2000-01-0546.pdf
I don't recall anybody testing MAF transient behavior as such, but it's gotta be more accurate
than trying to use the fuel characteristic.
My only caveat is that - at least in the older GM ECM's -
there is a lot of signal buffering that goes on before the sensor data is read by the CPU/sent out to
the ALDL line. You maybe need to tap into the raw data (before buffering/averaging) to get high-
quality MAF numbers for evaluation.
As to your calc, that's a litttle more gnarly. The industry rule of thumb (as you know) is to use 0.6
BSFC for supercharged engines. However as I read that, it's not-to-exceed design point that doesn't
take into account correcting the intake flow to standard temp & pressure. Your MAF should be reading
more like ACFM, so at first blush the BSFC ought to look more like a standard small block (albiet
one with very high CR). You are on the right track, but I dunno myself exactly where that takes
you for absolute accuracy of the result. But I know of the guy I would ask:
This board
http://www.turbobuick.com/forums/ does a lot with forced induction, and there
is one guy named GNJones I see posting in the ECM section from time to time. He's at NASA in
Houston, and has done a lot with instrumenting his Turbo Buick. He (or one of the others on that
board) might take you right where you want to go.
Does that answer your question at all?
I have a couple of new things I'm trying to get ready for spring:
Picked up a Northstar 4-coil ignition pack. I think I know how to interface that with my ECM,
but I have to finish some trigger-wheel testing before I'll know for sure.
Also started trying to write some new code for the old 727 ECM. For that I need to finish my ECM
emulator for code testing:
http://temp.corvetteforum.net/c4/doc...atorboards.jpg
You ever work in Assembly language? That stuff is a real PITA.
Later,
Dave
