Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-23-2004, 05:58 AM   #1
C490Vette
CF Senior Member
C490Vette's Avatar
Send a message via AIM to C490Vette
Default Code 45
While cruising at a constant highway speed for atleast 10 min. or more, I get a check engine light. The light goes out almost imediatly after accelerating or decelerating. I pulled the codes and get an error code of 45, Rich Exhaust present. What exactly does that mean and what do I have to do to fix it? The website where I read about the codes says to "check evaporative charcoal canister for smell of fuel (which normally comes from filling fuel tank to full). check fuel pressure regulator. Possible leaking fuel injector or sticking/bad EGR valve. Possible bad Oxygen sensor." I do get quite a fuel smell when the car first starts up. Any clues on which of the possible problems listed above could be causing the code? Thanx!
C490Vette is offline   Reply With Quote
Old 02-23-2004, 11:26 PM   #2
Vett-eight-nine
CF Senior Member
Vett-eight-nine's Avatar
Default Re: Code 45 (C490Vette)
Mine came up this way too. I replaced the O2 sensor, egr valve (code came up too) and there was definitely a bad injector involved. Now I have to see about emissions again which it failed horribly first time around. Good luck.
Vett-eight-nine is offline   Reply With Quote
Reload this Page Code 45
Tags
45, code, corvette, error
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
