Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-21-2004, 11:53 PM   #1
emoshn
CF Senior Member
Default Problems with codes
Car has been idling poorly, especially on initial fireup...thought it was the IAC being dirty or blocked, so I got the kit to rebuild the TB, but before I got started on that, decideed to run some tests to see if any codes were showing.
I have the cheapie little Killebrew thing which basically just replaces the paperclip. Has several different plugins for various systems. Knew I had problems with the FX3 system and pulled those codes. Then I put in the ECM plug: Codes: 16, 26. & 32. Then I plug in the CCM plug in: codes (and it shows a small number) 1. H74 4. H16, H26, H32 (which interestingly are the same as the ECM codes) 9 --- 1.0 --- and finally the SIR plug flashed 12/13/12/13.
This stuff just plain scares me. I know 32 is EGR associated ( just replaced the EGR and EGR solenoid last year). what are the others?
Any help will really be appreciated. a real novice here. I have an AC/DC volt and ohm tool and that's about it.
Thanks...and please be gentle. :banghead:
emoshn is offline   Reply With Quote
Old 02-27-2004, 01:55 AM   #2
vinnies87
CF Senior Member
St. Jude '03-'04-'05-'06-'07
vinnies87's Avatar
Default Re: Problems with codes (emoshn)
Have an 87 and check gm codes: can't find 16 or 26, but 32 is the EGR
good luck... sure someone else will chime in.
vinnies87 is offline   Reply With Quote
Old 02-28-2004, 09:30 AM   #3
Steel Blue 91
CF Senior Member
Steel Blue 91's Avatar
Try this site.
http://www.c4vettes.com/
Under "In Depth Info" Check "ECM COdes". Under "Fact Sheets" look at "Trouble Code Recovery". It will be a place to start. Also, the "H" in front of the code is a history code.
Good luck.
Steel Blue 91 is offline   Reply With Quote
Reload this Page Problems with codes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Sound System Packages at Complete Dreams accidentprone C6 Corvette General Discussion 36 06-10-2005 12:55 PM
Need Help with Codes - ABS, Active Handling/Traction Control ArrestMeRed C5 Scan & Tune 13 06-29-2004 12:50 AM
BIG PROBLEMS WITH MY ATI OVERNIGHT!!! BLOWN IN NC C5 Forced Induction/Nitrous 15 01-05-2003 01:13 AM
Problems with LPE SC???? BlackSun! C5 Forced Induction/Nitrous 20 09-04-2002 11:50 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
