Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-20-2004, 11:05 PM   #1
RUKWKR
CF Senior Member
RUKWKR's Avatar
Default Tried out Datamaster software tonight my car never went into closed loop?
Anybody have the requirements for closed loop handy? I have an electric water pump, 160 deg tstat, ambient temp was 50 deg and I don't think I ever saw a coolant temp >180 until I turned the A/C on. I think the coolant temp has to be hotter than that for closed loop right?
Next question, I kept getting a "Lost COM" error - anyone had that happen?
THANKS!
RUKWKR is offline   Reply With Quote
Old 02-21-2004, 12:10 AM   #2
AGENT 86
CF Senior Member
AGENT 86's Avatar
Default Re: Tried out Datamaster software tonight my car never went into closed loop? (RUKWKR)
My car goes closed around 140. I run a 160 stat with no problems going into closed loop.
I use datamaster also :confused:
Maybe a glitch :smash:
:cheers:
AGENT 86 is offline   Reply With Quote
Old 02-23-2004, 12:01 PM   #3
h rocks
CF Senior Member
h rocks's Avatar
Your link to the ALDL obviously was not communicating with your laptop. I don't know about the Datamaster interface, but does it need a 12v supply? sometimes I've seen the lighter plug get loose on not positioned properly, and I've lost the "comm" to my Ease PC Scan Tool.
If you were basing your comment on the car staying in open loop based on that, I would discount that info until you can verify that you have a solid link to your laptop program.
h rocks is offline   Reply With Quote
Old 02-23-2004, 01:47 PM   #4
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Most EE calibrations require about 92 degrees of coolant temp before going into closed loop. However the PCM may not allow closed loop until it sees the O2 sensor bounce above 450mV and then go below 450mV once it sees that and the minimum coolant temp it should go into closed loop.
tjwong is offline   Reply With Quote
Old 02-23-2004, 02:48 PM   #5
Z06_BluByU
CF Senior Member
Z06_BluByU's Avatar
Default Re: Tried out Datamaster software tonight my car never went into closed loop? (tjwong)
are you running headers by chance?
Z06_BluByU is offline   Reply With Quote
Old 02-25-2004, 09:55 PM   #6
RUKWKR
CF Senior Member
RUKWKR's Avatar
I've had a link up long enough to really study the data. I do have headers by the way?
I am almost positive my left O2 is toast because I had a left O2 code and also the left O2 millivolts are not even changing so it's not coming up to temp. I'm gonna put in a new O2 sensor and see if that fixes it.
I think the Lost COM error is resolvable once I get a chance to talk to the Datamaster folks. There manual mentions having problems with Vettes that have CCM issues, which mine does since it's been converted to OBD-I
Thanks!
Reload this Page Tried out Datamaster software tonight my car never went into closed loop?
Tags
camaro, datamaster, working
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
