Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-13-2004, 04:48 PM   #1
2ND GUNMAN
Junior Member
Default NEED: LT4 Bin File (Converted OBD1)
Looking for a stock LT4 bin file. I found a converted LT4 OBD1 file in the
archives but it won't download anymore. Anyone have one, in .bin or .lt1 format (either is OK)? TIA. Email:
mrboston3@earthlink.net
2ND GUNMAN is offline   Reply With Quote
Old 02-16-2004, 12:07 AM   #2
DR'76
CF Senior Member
DR'76's Avatar
Default Re: NEED: LT4 Bin File (2ND GUNMAN)
You have mail!
DR'76 is offline   Reply With Quote
Old 02-16-2004, 12:56 AM   #3
2ND GUNMAN
Junior Member
Default Re: NEED: LT4 Bin File (DR'76)
Got it. Thanks.
Old 02-16-2004, 10:33 PM   #4
GlockLT4
CF Senior Member
GlockLT4's Avatar
Send a message via AIM to GlockLT4
I have it too... man, i wish it was that easy when i needed it . I had to do it myself. You probably got the one i made, haha. I should have added a watermark to it to keep track
GlockLT4 is offline   Reply With Quote
Old 02-19-2004, 02:07 PM   #5
bspvette86
Junior Member
bspvette86's Avatar
I could use a copy of these too. I've done most of the conversion manually myself, but would like some more Bins for comparison.
Cheers!
Karl
bspvette86 is offline   Reply With Quote
Old 03-20-2004, 02:25 AM   #6
lcvette
CF Senior Member
lcvette's Avatar
Send a message via AIM to lcvette
hey guys..have any of you done the OBD2 to OBD1 conversion? I am in the process of figuring it out and could really use soem help.. what i have is a 96 LT4.. and the ECM in it..also have a 95 M6 PCM here for the conversion to OBD1.. i read about impala swaps and they say knocks sensor pinout change which i understand and tach signal which is fuzzy..are both these things what needs to be changed on the Y-body? also what else if anything needs to be done and what to expect afterwards.. can it be scanned tuned normally? thanks in advance!
Chris
lcvette is offline   Reply With Quote
Old 03-20-2004, 02:31 AM   #7
GlockLT4
CF Senior Member
GlockLT4's Avatar
Default Re: NEED: LT4 Bin File (lcvette)
I'm running the OBDI in mine. You have to change the resistance level of the knock sensors (i forget the amount). After that, it's just the same. You can use all your OBDI stuff just like normal. I tune my LT4 just like i did my '94 .
Old 03-22-2004, 10:31 PM   #8
GS057
CF Senior Member
GS057's Avatar
Default Re: NEED: LT4 Bin File (GlockLT4)
DR'76, Please send me a copy of the OBD I LT-4 Bin File to:
meyre1@aol.com
Thanks,Michael
GS057 is offline   Reply With Quote
Old 03-28-2004, 12:33 AM   #9
95Purple
CF Senior Member
95Purple's Avatar
Send a message via AIM to 95Purple
Hello Could I get a copy of this too in .lt1??
95Purple is offline   Reply With Quote
Old 03-28-2004, 08:18 PM   #10
DR'76
CF Senior Member
DR'76's Avatar
Default Re: NEED: LT4 Bin File (95Purple)
I'll forward you a copy in .bin format....I used to have a conversion program, but can't find it!
I think it's at 3rdGen.org thirdgen.org. There's also some files here: http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
I'll post back when I find that conversion file...
Dr.
Old 04-07-2004, 01:47 AM   #11
GlockLT4
CF Senior Member
GlockLT4's Avatar
Did you guys all get the obdi version of the LT4 program? If not, let me know and I'll get it to you.
Old 04-07-2004, 09:44 AM   #12
MSR
CF Senior Member
MSR's Avatar
i found tables that are relevant to fueling which are not available in lt1_edit, so you can't really do a 100% conversion. the difference was large enough that swapping ecms from obd-2 to obd-1 with everything converted that was available to me ended up with different fuel trims, sometimes as much as 10%.
-michael
MSR is offline   Reply With Quote
Old 05-03-2004, 12:06 PM   #13
GlockLT4
CF Senior Member
GlockLT4's Avatar
Default Re: NEED: LT4 Bin File (MSR)
That's interesting.. my fuel trims seem to be pretty good.
Old 05-03-2004, 11:06 PM   #14
rsafier
CF Senior Member
rsafier's Avatar
Send a message via AIM to rsafier
If someone could forward me a copy of a LT4 Bin file that would be great. I would like to compare my current BIN to it.
rsafier is offline   Reply With Quote
Old 05-03-2004, 11:14 PM   #15
GlockLT4
CF Senior Member
GlockLT4's Avatar
Default Re: NEED: LT4 Bin File (rsafier)
you've got mail!
Old 05-05-2004, 10:35 PM   #16
carriljc
CF Senior Member
carriljc's Avatar
Default Think that LT4 OBD1 Bin will work in a RamJet 350?
That I'm controlling with 1227730? Sounds like the specs could be close.
carriljc is offline   Reply With Quote
Old 05-08-2004, 11:23 PM   #17
NC-LT4
Junior Member
NC-LT4's Avatar
Default OBD-I question from a newby
I am considering converting my '96 to a OBD-I. Can I use any LT1 OBD-I PCM? (Buick, Caddy, Impala, Caprice, F-Body or y-Body).
Thanks for the info.
NC-LT4 is offline   Reply With Quote
Old 05-08-2004, 11:27 PM   #18
GlockLT4
CF Senior Member
GlockLT4's Avatar
Default Re: OBD-I question from a newby (NC-LT4)
needs to be Vette or F-body. And don't use an f-body based program or your Auto A/C won't work. I forget the model numbers on the computers but can go look if you need it.
Old 05-09-2004, 12:52 AM   #19
DR'76
CF Senior Member
DR'76's Avatar
Default Re: OBD-I question from a newby (GlockLT4)
The F-body (and I believe Caprice) PCM is 16188051, the Y-body is 16181333.
*GlockLT4:
What's this about the A/C and the F-body PCM? I'm using the F-body PCM for a '95 LT1 installed in a '76 Vette (C3) and am about to button up the A/C...should I be concerned about anything? It's mighty hot here in FL!
Old 05-09-2004, 10:59 AM   #20
NC-LT4
Junior Member
NC-LT4's Avatar
Thanks for the info gents. In addition to the auto ac, I was wondering about the other guages working with the OBD-1 PCM, like the fuel monitoring system in the '96.
What base program is recommended?
I apoligize if this discussion has been already been beat to death in the past. If it has please steer me to the appropriate source.
Thanks again..........Jim
Reload this Page NEED: LT4 Bin File (Converted OBD1)
Tags
1996, 95, bin, corvette, engine, file, files, gm, lt4, obd, obd1, stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
