Quote:
Is it better do disable closed loop operation while tuning; and then when you've got it "right", then switch on closed loop? TIA
I would agree with you if you are close. If your not close (big cam/big changes) I would leave BLM and Short term guys alone-the point will be to get it within +/-15%.
I actually went through a stage where I only allowed the ECM to add fuel (but not take any away). Starting with a WB and datamaster took fuel fuel away until the car went into closed loop. This got me within 5 to 10%.
Then I completely disengaged the BLM and Short Term. Unfortunately my car seems to run better without ECM help than with. Depending on the day, it got me within 5%.
Random note:
1) If anything, I'd disable the the AFR% adjustment for Open loop (I set mine th 2% except at 90/100 load where it is 13%/14%
2) As difficult as it may seem...only change 1 thing at a time. This is especially true for the idle as about 6 differect tables effect it.
3) adjust timing OR VE tables, not both
4) Take notes of what VE generated what AFR
