Here are deviations from Davis's outline per Bluevette85 awhile back.
Bluevette85
Senior Member
1291 posts [100%]
Latham NY
Title: 870 to 165 Conversion Instructions 5:28 PM 2/6/2003
This seems to be a popular topic recently. I have sent several members my instructions for this so I figured I would post it here.
DISCLAIMER: This worked for me on the stock TPI and on my Superram conversion. You should double check all wiring yourself because it is easy to misconnect something and fry the ECM. Do this at your own risk.
These two sites have information you can use. The davis site has some
errors and I have noted the corrections below.
http://www.chevythunder.com/fuel%20i...%20pinouts.htm
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
The pin changes below are one way only. i.e. A11 gets moved to C12 but C12
does not go to A11.
There are a few connection changes from what davis posted on his site.
870_________165
A11----------------C12
D2-----------------C1
D8-----------------C15
B4------------------D4
+D12---------------D2
C9------------------D11
B11-----------------B12
+D13---------------A11
+D14---------------D16
+D15---------------D15
*Combine the old C15 into the old D14 (which is now the new D16)
*Combine the old D16 into the old D15 (which is the new D15, it doesn't
change)
+ indicates differences in what davis says to do.
The original C12 is a redundent wire and is not connected to anything in the
165.
You can use your 85 MAF without a problem. From what I have read, the 85
MAF can be used in 86-89 but 86-89 cannot be used in 85.
Buy the MAF relay connectors at Napa #EC85, $4.49 each. The two relays are slightly different. The power relay uses all 5 pins but the burn-off uses
only 4 pins. You can use the power relay for both but I used one of each
type. I use the relays for an 86.
There is a six connector plug coming off the 870 ecm wires which goes to the
burnoff module behind the breadbox. You must disconnect this or your
conversion won't work. This plug is lettered and this is what davis calls
the "MAS connector". The relay connectors you buy from NAPA are labeled
ABCDE and you connect everything as follows: (some changes from what davis posted) I put the relay connectors under the dash with the ecm wires so I didn't have to run a bunch of wires into the engine bay.
MAF Burnoff Connector pin A----------MAS pin D
MAF Burnoff Connector pin B----------must run a new line to D12 on ecm connector. You must buy ecm connector pins.
MAF Burnoff Connector pin C----------MAS pin A
MAF Burnoff Connector pin D----------not connected to anything
MAF Burnoff Connector pin E-----------MAS pin A
MAF Power Connector pin A---------MAS pin F
MAF Power Connector pin B---------MAS pin E
MAF Power Connector pin C---------splice into ecm pin B2
MAF Power Connector pin D---------MAS pin D
MAF Power Connector pin E--------- MAS pin A
I tried to use the 870 burnoff module instead of the relays but it wouldn't
work so adding the relays was the only solution.
