Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-06-2004, 09:17 PM   #1
1MoorTym
CF Senior Member
Default Where can I get an .ecu
Just download WinBin and stock bin file for 89.
Where can I get an ecu file for the 1227165 ecm with a 6e mask ?
Is there a better program than winbin to poke around the bin file?
1MoorTym is offline   Reply With Quote
Old 02-08-2004, 08:20 PM   #2
SBNova
CF Senior Member
SBNova's Avatar
Default Re: Where can I get an .ecu (1MoorTym)
I use tunerpro. Its free also and has the 6E ecu included. Check thirdgen.org for a link, look under DIY-Prom section.
SBNova is offline   Reply With Quote
Old 02-09-2004, 01:45 PM   #3
Bluevette85
CF Senior Member
Bluevette85's Avatar
tunerpro.markmansur.com
Bluevette85 is offline   Reply With Quote
Old 02-10-2004, 10:41 AM   #4
1MoorTym
CF Senior Member
Default Re: Where can I get an .ecu (Bluevette85)
thanks I got, but as stated there may be variances in the accuracy of these files.
Have you had any issues using this one ?? Anyway to determine if this one is correct??
Old 02-10-2004, 11:04 AM   #5
SBNova
CF Senior Member
SBNova's Avatar
What files?? your bin or the TunerPro? Tunerpro is from a reputable source, bins are available everywhere, there are a few links on this site. Download a few and compare them using the "compare" feature and you will see differences/discrepancies. Hust make sure its a 6E bin, or it definately wont look right when you open it.
Old 02-10-2004, 07:37 PM   #6
1MoorTym
CF Senior Member
Default Re: Where can I get an .ecu (SBNova)
The ecu template file. I figure most of the bins people post are modified but the template file should be untouched. According to tunerpro's site using a modified one can have some negative effects -
From the site
The ECU file format is a public-domain format. As a result, there are few assurances to the accuracy of ECU files that can be found in various places on the web, etc. It should be understood that in some cases you can do hard to your engine if you tune using an inaccurate ECU file. I have made every effort to validate the accuracy of the $6E ecu file in the "supported by author" list. The others are to be used at your own risk.
[Modified by 1MoorTym, 6:40 PM 2/10/2004]
Reload this Page Where can I get an .ecu
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I saw me like 4 years ago... kopbet89c4 C4 General Discussion 19 03-10-2005 04:11 PM
Put an 85 EFI setup on this motor or no? kpforce1 C4 Tech/Performance 9 12-07-2004 01:02 AM
How much can I expect to pay for DFI setup zelement C4 Tech/Performance 49 05-07-2004 09:51 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
