Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2004, 11:36 AM   #1
spinedoc
CF Senior Member
spinedoc's Avatar
Default need advice on reprogramming
I purchased a 96LT4 with a leaking head gasket and am modifying it. I am adding long tube headers, porting the heads and intake, and installing a hotcam or similar grind. Also adding a lower thermostat and 4.10 gears.
My question is, i have no idea what needs to be done to the ecm. I have never modified a computer controlled vehicle and am lost. Can i send the computer out to be redone? What should be done. I have heard of people altering spark advance, idle, fan, speedo, etc. It sounds like this is something i need to do, but I am not capable of doing ti myself. Also, when this is done, is there still trial and error such as on a carb'd vehicle, with tweaks here and there till it runs right? I have heard of some reprograms just not being spot on. I am nervous about dumping monet and effort into the car and not having it perform as well as it can.
Any advice or leads would be greatly appreciated. Thanks!
:seeya
eric
spinedoc is offline   Reply With Quote
Old 02-05-2004, 12:43 PM   #2
Aaron's 87
CF Senior Member
Default Re: need advice on reprogramming (spinedoc)
Can i send the computer out to be redone? Yes
What should be done. Depends on the mods - probably everything you mentioned +
It sounds like this is something i need to do, but I am not capable of doing ti myself. Why not?
Also, when this is done, is there still trial and error such as on a carb'd vehicle, with tweaks here and there till it runs right? Sorry to be Bill Clinton, but it depends on your definition of right.
I have heard of some reprograms just not being spot on. Definitely
I am nervous about dumping monet and effort into the car and not having it perform as well as it can. Then you'll have to invest money into equipment and lots of time into learning and trial and error.
Aaron's 87 is offline   Reply With Quote
Old 02-06-2004, 11:33 AM   #3
spinedoc
CF Senior Member
spinedoc's Avatar
OK, so what exactly do I need to reprogram my ECM? a computer? Software? How would a novice begin to tackle this problem??
Old 02-06-2004, 05:58 PM   #4
gregfloyd
CF Senior Member
I program my own chips and have done about 2 dozen more for other people.. here is a good link to start your journey for knowledge.
This article is what started it all for me
http://www.thirdgen.org/newdesign/tech/promintro.shtml
gregfloyd is offline   Reply With Quote
Reload this Page need advice on reprogramming
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Advice on Upgrading my C4 Automatic 2.73 Rear Differential. hoot85 C4 Tech/Performance 18 01-22-2004 04:01 PM
torque converter and rear gear advice needed curtowens C5 Tech 52 04-29-2003 02:02 AM
Need advice on modding 96LT4, zf6. MrCrowley C4 Tech/Performance 35 12-05-2002 11:41 AM
Need Advice on Pros & Cons of installing a Powerloader II Oh Cool C5 Tech 22 03-25-2002 11:05 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
