Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2004, 09:42 AM   #1
Ramanstud
CF Senior Member
Ramanstud's Avatar
Send a message via AIM to Ramanstud
Default Datamaster and 86-89 ALDL
Has anyone had connection problems with DataMaster on an `86 ECM? I'm using a radioshack USB-serial emulator and one of those ebay special ALDL things (with a 10K-ohm resister between A&B). It works for WinALDL but not for DataMaster- is that because DM is more finicky or am I just doing something wrong?
I even went through the DM manual and did all of the software changes recommended therein. Sometimes it will recognize the PCM and just not connect, other times it won't even tell me that the PCM is hooked up....
:banghead:
I was running Win2000 on my laptop, but I'm switching back to Win98 for software reasons (driver availability) so I'll see if that changes anything...
[Modified by Ramanstud, 1:33 PM 2/2/2004]
Ramanstud is offline   Reply With Quote
Old 02-02-2004, 11:21 AM   #2
Black87c4
CF Senior Member
Black87c4's Avatar
Default Re: Datamaster and 86-89 ALDL (Ramanstud)
Not used all of em but found datamaster to be the most stable one so far, heard of many having issues with usb cards.
Black87c4 is offline   Reply With Quote
Old 02-02-2004, 02:05 PM   #3
Bluevette85
CF Senior Member
Bluevette85's Avatar
The resistor should be 10k (10,000) ohms not 10 ohms.
Bluevette85 is offline   Reply With Quote
Old 02-02-2004, 02:33 PM   #4
Ramanstud
CF Senior Member
Ramanstud's Avatar
Default Re: Datamaster and 86-89 ALDL (Bluevette85)
That's what I meant... sorry!
Old 02-02-2004, 11:08 PM   #5
AGENT 86
CF Senior Member
AGENT 86's Avatar
I have no problems and I'm using homemade cable.
I'm using a serail port though
:cheers:
AGENT 86 is offline   Reply With Quote
Old 02-02-2004, 11:09 PM   #6
AGENT 86
CF Senior Member
AGENT 86's Avatar
Default Re: Datamaster and 86-89 ALDL (AGENT 86)
Are you trying to log or monitor ?
Have you read how to open file so you can log ?
Old 02-03-2004, 12:57 AM   #7
Ramanstud
CF Senior Member
Ramanstud's Avatar
Yeah, I went through the directions step-by-step, so that it's all hooked up and rarin' to go- it just won't find the PCM or receive data. I checked all the "USB cable" and "Disable ALDL handshake" options, etc etc... but it's just not finding the PCM. I'm reverting my laptop back to Win98 (from Win2000) just to see if that will ease some of the problems I've been having with drivers. If that doesn't work, then I suppose I'll just throw a tantrum and start throwing inexpensive personal belongings.
:lol:
Old 02-03-2004, 12:38 PM   #8
vinnies87
CF Senior Member
St. Jude '03-'04-'05-'06-'07
vinnies87's Avatar
:lol: :lol: :lol:
vinnies87 is offline   Reply With Quote
Old 02-06-2004, 09:24 PM   #9
gregfloyd
CF Senior Member
Default Re: Datamaster and 86-89 ALDL (vinnies87)
Try using the ALDL test program from TTSpowersystems.. It will let you know if you are communicating fron the laptop to the aldl interface
gregfloyd is offline   Reply With Quote
Old 02-16-2004, 05:20 PM   #10
ZD1
CF Senior Member
ZD1's Avatar
I had to go from win95 to XP Pro
ZD1 is offline   Reply With Quote
Old 02-16-2004, 09:04 PM   #11
JCAIRE2
CF Senior Member
JCAIRE2's Avatar
You need a MAX-232 based cable similar to the one made by steve ruse at WOT electronics. Do a google search and see if your cable looks like his. If it's just the regular 2 transistor cable, it will not work with DM. But it should work with Freescan and Craig Moates's software. :cheers:
JCAIRE2 is offline   Reply With Quote
Reload this Page Datamaster and 86-89 ALDL
Tags
86, 89, aldl, corvette, datamaster, handshaking, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
