Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-31-2004, 09:49 PM   #1
Trog
CF Senior Member
Trog's Avatar
Default L98 IAC & TPS adjust
Hi there,
I have a '90 L98 w/ a few mods.
Just for kicks I decided to check these settings per both my service manual & the forum techs.
Anyway, IAC was fine, the plug was still in the adjuster screw hole & it was right at 450.
So, check TPS & its at .66 at base & goes up smoothly to about 4.7 by my volt meter. However, it doesn't appear that mine is adjustable. I didn't pull the screws but I can tell from the shape of the plastic that there is not room for a slot.
Anyone with experience on my year please chime in.
Thanks!
Trog is offline   Reply With Quote
Old 02-01-2004, 09:56 AM   #2
AGENT 86
CF Senior Member
AGENT 86's Avatar
Default Re: L98 IAC & TPS adjust (Trog)
They switched to a non adjustable, and I believe your year is on that list
:cheers:
AGENT 86 is offline   Reply With Quote
Old 02-01-2004, 11:07 AM   #3
Wildride
CF Senior Member
Cruise-In II Veteran
Wildride's Avatar
The 1990 and 1991 L98 TPS (which have a "Speed Density system vs. the Mass Air Flow system and adjustable TPS of the earlier engines) voltage is compensated for by the computer. There is no need to adjust the TPS.
Normal voltage at idle (Upper Radiator hose hot/closed throttle/Park or Neutral/closed loop/Acc. off) is .36 to .96 volts.
It looks like you are OK!
Wildride is offline   Reply With Quote
Old 02-01-2004, 05:24 PM   #4
Trog
CF Senior Member
Trog's Avatar
Default Re: L98 IAC & TPS adjust (Wildride)
Okay, cool! Thanks!!
On the subject of scan/tune. Next thing I'd like to do is check if my non-heated O2 is working properly. I was thinking Moates software & my laptop... but I need to come up w/ a cable.
What is a recommended source or should I just try & build one?
Old 02-01-2004, 06:41 PM   #5
Wildride
CF Senior Member
Wildride's Avatar
I built my interface cable that works fine from a kit provided by AKM Cables. Andy can provide ready made cables also-just a bit more expensive but guaranteed to work.
http://www.akmcables.com/
BTW: The specs on the TPS are direct from the GM Service Manual for the 1990 Corvette. (Page 6E3-A-12)
[Modified by Wildride, 4:45 PM 2/1/2004]
Old 02-01-2004, 07:39 PM   #6
Trog
CF Senior Member
Trog's Avatar
Dang... cables aren't cheap... even just the parts...
Old 02-01-2004, 11:48 PM   #7
gregfloyd
CF Senior Member
I have this aldl interface permanently mounted in my car
http://www.makinterface.com/index_e.php3
it is like 58 bucks
gregfloyd is offline   Reply With Quote
Old 02-02-2004, 02:24 PM   #8
Trog
CF Senior Member
Trog's Avatar
Default Re: L98 IAC & TPS adjust (gregfloyd)
What year is your car?? From what I can tell, mine is right in the range of years before version II but not exactly version I either??
Reload this Page L98 IAC & TPS adjust
Tags
1990, 1991, addjusting, adjust, adjustment, air, c4, control, corvet, corvette, iac, idle, l98, setting, tps
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Throttle body problem hpbadger C4 Tech/Performance 22 02-02-2005 04:36 PM
L98 idle set procedure? scorp508 C4 Tech/Performance 13 07-11-2003 11:59 PM
TB cable adjust made a difference... Lone Ranger C4 Tech/Performance 10 03-24-2002 09:32 PM
High IAC counts (128~160), can't get it down with timing/idle, ideas? C4 Tech/Performance 17 03-13-2002 02:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
