LPE 211 or TPIS ZZ-9? (poll)
Old 04-27-2003, 08:09 PM
ROADAPPLE
ROADAPPLE's Avatar
Default LPE 211 or TPIS ZZ-9? (poll)
The time has come for a cam and head upgrade. I am retaining the TPI style intake set up as listed in my sig. Which cam do you recommend?
Old 04-27-2003, 09:02 PM
87Beast
87Beast's Avatar
Default Re: LPE 211 or TPIS ZZ-9? (C44ever)
I've had the ZZ-9 coupled w/AFR 190 since '99 and highly recommend it for L-98. Not sure about the LPE 211. If you want the specs I could provide them.
Old 04-27-2003, 09:16 PM
severe-1
severe-1's Avatar
Default Re: LPE 211 or TPIS ZZ-9? (87Beast)
I'd call comp cams and see what they recomend. When I was selecting a cam, I used the desktop dyno program to plug in many different cams. The cam they recomended made the most power on the dyno program. Umfortunately it was backordered....
Old 04-27-2003, 09:19 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
For an example of the ZZ-9 on a TPI L98 check out results of mods to a L98 on my site.
I would like to see similar results of the 211 on a TPI engine.
Old 04-28-2003, 02:54 PM
Fast Glass
Fast Glass's Avatar
I've never tried the LPE, but the ZZ-9 has been in my car for close to 5 years now. It runs strong, sounds good and am very pleased with it.
Old 04-28-2003, 05:06 PM
flynhi
flynhi's Avatar
I have a 211 in my LPE 383 with CNC'd 90 GM heads and large runner tpi. It makes good power across the curve (see sig) even tho it was designed for a superram.
[Modified by flynhi, 4:08 PM 4/28/2003]
To LPE 211 or TPIS ZZ-9? (poll)
Quick Reply: LPE 211 or TPIS ZZ-9? (poll)
