Help with Ostrich!
Help with Ostrich!
Im having problems getting ostrich to work, I think I may have the incorrect bin but im not sure.
So I can connect with tunerproRT and I can upload the bin/download.. verify but I cannot make a connection to the ECU with datamaster/ALDLDroid.
The web is really confusing as to what mask to use, iv spent hours searching around before I even attempted to use ostrich and settled on the $DA3 mask for my first attempt, ALDLDroid uses a $DA3.adx file that the creater made for me and was able to log the car with only a slight mathematics issue witch is why I started there, Well with Ostrich plugged in and the $DA3 bin I found on the web uploaded.. no luck!
So I tried a $DA2 setup.. same thing, cannot connect so I did not even try to start the car obviously.
I found a BAFL vette 5.7 LT1 6speed bin on the web and tried that with the same result..
The car is a 93 6 speed, Moates says to use $DA2.
So does anyone have a bin for a 93 6speed or have any other insight?
Thanks.
Thanks.
