Hard to start 1986 Corvette
Old 06-22-2014, 09:00 PM
Axeman32
2nd Gear
Axeman32's Avatar
Default Hard to start 1986 Corvette
I recently purchased my first Corvette. A 1986. 71000 miles. It runs great but after I drive it awhile and shut it off, It starts very hard. It does start but takes a few cranks? any Ideas??
Old 06-23-2014, 12:53 AM
Cliff Harris
Cliff Harris's Avatar
Check for error codes:
http://corvettephotographs.com/c4vettes/codes.htm
http://forums.corvetteforum.com/1574918379-post18.html
What they mean:
http://forums.corvetteforum.com/1576116036-post35.html
You might have a bad CTS (Coolant Temperature Sensor). The one for the ECM is located on the front of the intake manifold under the throttle body. If the connector is corroded or the connection is broken the ECM will think the coolant is very cold and will richen the mixture.
Old 06-23-2014, 02:31 PM
jsiddall
jsiddall's Avatar
Leaky injectors can also cause hard restart due to essentially flooding the engine. One way to check for this is to hold the accelerator to the floor before cranking and until it starts. If it starts easier doing this than normal then you likely have bad injectors.
Old 06-23-2014, 08:43 PM
Axeman32
2nd Gear
Axeman32's Avatar
Thanks Ill check both items.
To Hard to start 1986 Corvette
Quick Reply: Hard to start 1986 Corvette
