Could my AE be toooo Rich?
Well i tried a new chip recently, and changed maybe too many things at once. I been reading up on AE, and saved an article that someone wrote, maybe on TGO. Explains how AE is calculated and what the tables/scalers do. There is alot involved with it, and it was geared towards the $8D tdf. So i made a bunch of changes giving it more pumpshot, mostly gave it more pulse width. But with 2 chips i made, it was real rich, black smoke, and puked or died when i gave throttle.
At first i thought it was a bad burn of the PROM. Then re-burn did not work either. Put in an older chip, known to work, it smoothed right out.
Now i will accept that too rich of tune will cause my condition.
I think what i will do is start over with that last good bin, and just make a few other changes that i want. Leave the AE stuff alone. I was just trying something, see if i could get a little more pump shot. Maybe i went too rich on my changes?
3.98
3.34
2.70
2.20
1.75
1.30
0.91
0.50
Those were my settings for AE TPS factor vs Ref Pulse. That table supposedly makes a big effect on the AE PW. I made changes to 2 other tables for multipliers of coolant PW and the delta TPS.
I just like experimenting. Some things work and some dont!
3.98
3.34
2.70
2.20
1.75
1.30
0.91
0.50
Well tonight burned a new chip, just changing a few little things, but left the AE stuff stock. Car started and seemed to run fine, but i didnt drive it. Anyone have some insight on AE settings?
I really dont want anyone to make a bin for me. I just cannot believe how i changed some AE tables, it made it that rich when i blip the throttle. I been trying to read up on the AE stuff. Just tried to use common logic and give it more PW during AE.
http://www.scotthansen.net/july302013.bin
You'll note the small amount I add to the AE delta TPS multi vs delta TPS
Here's mine.
the table that makes the MOST change to the AE PW is AE TPS factor vs ref pulse. Most bins i have seen have 3.98 in the first row(max allowed) then have 0.50 for the rest of the pulses. What i did was take this table and make a linear graph down to 0.50 for the last pulse. See my values in the first post. I'm guessing this was too much PW for my engine.
The basic procedure is to log your AFR and see what percentage change is needed. You need a wideband O2 sensor to do this.
In logs I've seen recently, the ECM locks the BLMs and INT to 128 at WOT, so that won't tell you anything.
