Setting base timing
Old 06-03-2014, 01:34 PM
1986Vette
1986Vette's Avatar
Default Setting base timing
I need to set the base timng on my 1986 corvette. Anyone have a pic of the wire I need to disconnect prior to setting the base timing
Old 06-03-2014, 09:34 PM
ANTI VENOM
ANTI VENOM's Avatar
No pic, sorry. If I remember correctly, its a brown wire and the connector is a black cylindrical piece. You push the two connector pieces together and turn 1/4 turn and it will come apart. The connector should be hanging out of the wire loom. It should be the only one that looks like that. I hope that helps, it's all I've got for now. Others will chime in.
Old 06-03-2014, 10:48 PM
Cliff Harris
Cliff Harris's Avatar
Tan wire with black stripe. Between the windshield wiper motor and brake booster. It is called the EST (Electronic Spark Timing) connector:
Old 06-04-2014, 02:39 AM
ANTI VENOM
ANTI VENOM's Avatar
Ok, I was close. HAHAHAHAA. I guess I'm not very detail oriented.
Old 06-04-2014, 12:02 PM
Z51breeder
Z51breeder's Avatar
Dont forget to disconnect your neg battery cable after you set the timing, because car will throw a code 42 for disconnecting that wire.
Old 06-04-2014, 01:24 PM
bjankuski
bjankuski's Avatar
You do not have to do this, if you reconnect the wire the check engine light will go off and the code will be cleared after 50 restarts. You can disconnect the battery if you want but I am trying to save you from reprogramming the radio.
Old 06-05-2014, 02:26 AM
Cliff Harris
It will show an SES light the first time you start the engine, but you will never see it again.
You're better off disconnecting the ECM power connector to reset the error codes. It only goes to the ECM so you don't lose your radio or HVAC settings:
To Setting base timing
Quick Reply: Setting base timing
