Could use some Help using an Autoxray xp240
Old 04-23-2014, 01:30 PM
charliet615
charliet615's Avatar
Default Could use some Help using an Autoxray xp240
I'm new to the Scan procedure, i purchased the xp240 and wanted to use it to scan my 93 auto. I have it configured with no problem. I have a couple of questions on how to use it. Any help would be appreciated..
Old 04-23-2014, 05:00 PM
MrWillys
MrWillys's Avatar
Press scan and then enter and it will read. Press data and chose trouble codes, or one of the other options. Great scanner btw.
Old 04-23-2014, 05:14 PM
charliet615
Ok, thanks for that, how does the Capture mode work? To do the first Scan, is the engine running or just turn the key on?
Old 04-23-2014, 05:27 PM
MrWillys
MrWillys's Avatar
I always scan with engine running. Never did figure out capture mode, but there's directions in the book.
Old 04-23-2014, 06:20 PM
charliet615
Tx Mr ******, the book is not very clear, at least to me anyway...I'm not to smart when it comes to electronic gadgets...I'm a whiz with mechanical things....
To Could use some Help using an Autoxray xp240
Quick Reply: Could use some Help using an Autoxray xp240
