limp mode??
Old 04-20-2014, 07:15 PM
943504bolt
Cruising
943504bolt's Avatar
Default limp mode??
Gotta 94 vette, after driving it a little, the transmission wants to start out from a complete stop in 3rd gear. To resolve this, i pull over and turn the car off for a min or two.....then it works fine for awhile....what could be my issue....car has 107000 miles, no check engine light , no codes on obd1 scanner, thanks guys..
Old 06-30-2014, 12:49 AM
paintburg
1st Gear
paintburg's Avatar
Default tran problem
Sounds like your solenoid or overdrive sticking
Old 07-03-2014, 03:54 AM
Cliff Harris
Cliff Harris's Avatar
Trans controller has a problem. i believe it's in the PCM on your car.
To limp mode??
Quick Reply: limp mode??
