88 165 ECU 160 baud?
I managed to get my ALDL datalog going through Tuner Pro RT but it seems pretty slow. Are we stuck at 160 baud only?
Thanks,
Aaron
Thanks,
Aaron
The 1227165 ECM defaults to sending data at 160 baud.
At the end of each set of data the ECM waits 50 ms (milliseconds -- 1/1000 of a second). If it receives a special series of bytes during that time it switches to 8192 baud. Once it switches it stays at 8192 baud. The data monitoring program must be able to handle this.
TunerPro RT can do it. It needs the correct data/setup template to do this. I think it's an .ADX file (I have TunerPro RT but have not used it very much).
