Need a good timing table!
Hey guys, I need a good timing table for my set up if anyone has one. I have a 350 L98 with the following mods:
Miniram
58MM Throttle Body
Flat tappet zz409 cam
1.6 roller rockers
AFR 195 Eliminator heads
Hedman long tube headers
10.3:1 compression ratio
The car is a 1985 Corvette. If anyone has one can you please send it over? Also can you tell me what base timing to run?
Thanks a lot!
Miniram
58MM Throttle Body
1.6 roller rockers
Thanks a lot!
