Setting the timing in the tune? 1985
Hey guys, I have a 1985 Corvette, and I have advanced my base timing to 10 degrees. I'm not sure that my tuner that I use has actually set the timing in the tune, or at least not properly, so I would like to check up on that myself so I might be able to solve a few idle problems.
Where are the tables or scalars to modify in the tune for base timing? And do I need to modify like total timing advance tables or anything? What should they be set at normally, and what should they be set at for 10 degrees? I just want to make sure that it is all set up properly, because if it isn't, I can just retard the timing to 6 degrees and see if I still have the idle problems.
Thanks a lot!
Thanks a lot!
Thanks a lot!
Thanks a lot!
Advancing base timing is really not necessary and can cause problems in other areas. If you want to make timing changes, use the Spark Advance vs. RPM vs. Load table under Tables. If idle is the problem you can adjust the timing at idle RPM.
If you are using Tuner Pro RT, go to the scalars and select Initial Spark Advance. It should be set to 6 degrees. If not, make it 6. Then adjust the distributor for 6 degrees.
And I assume that the left hand side of the Spark Advance vs. RPM vs. Load table is the RPMs, and the middle area is all timing advance degrees, but I don't understand the numbers in the top line, I guess they are Loads? What are loads measured in? What do those numbers mean? Thanks a lot for your help!
Okay thanks a lot! My tune was set at 9.84 for the Initial Spark Advance. My timing is supposed to be 10 degrees, should I change it to 10?
The numbers at the top are load. The higher the number, the more load. Its a value calculated by the computer. This is one of the weaknesses with the 85 ECM. Data logs do not record load. So there's guesswork involved in making timing changes.
It's going to be hard to help you without knowing what your tuner was doing.
My recommendation is set it to 6.
When I compared the two tunes, stock tune and my current tune, there was no changes in that table. The only change was in the Initial Spark Advance scalar. I set it to 10 and it reverted back to 9.84.
If it's not going to effect my power, I would have no problem going back to 6*.
Thanks a lot!
Thanks a lot!
Will I feel a difference if I move back down to 6 degrees, or nothing at all?
I do not understand what your tuner was trying to accomplish. 6 degrees is the factory setting. Adding 4 degrees everywhere means you will be running over 50 degrees of total timing in some areas. But to answer your question, I don't think it will run any worse putting it back to 6.
The good thing about these changes is that you can always go back.
First, 9.84 vs. 10 means nothing. That's a Tuner Pro thing.
I've taken out 4 degrees globally out of the spark table for engines with big cams, and set initial to 10. Do what the tuner tells you, because he may have a reason.
Basically it's used when you hit the gas (throttle blades opened -- high TPS) but the air flow (and RPM) hasn't caught up yet. It can also be used in a situation like going up a steep hill where you mash on the gas pedal but the engine doesn't have enough power to make the car accelerate (at least not very fast).
