Lingenfelter Superam
Mine is a 350cu in, AFR 195 heads, thanks Jim, Lingenfelter 74211 cam , 52 TB, hooker headers.
Does anyone have a tune for a similar set up that they would share? I have my tune real close using Tuner Pro but would like to see what some are using for timing etc. especially around idle. Mine idles pretty good just want to see a comparison.
Thanks!
Thanks!
I'm just getting into this data logging. I'm going to have a lot of questions probably for you 2 guys among others.
My car don't idle for sheite!
Thanks!
Thanks!
Try this:
http://www.scotthansen.net/cshumansburn.bin
right click and choose save target as.
Let me know what you think?
Try this:
Thanks!
Try this:
I compared your bin to my current bin and the timing at idle is a degree or two lower than mine. I also noticed that your timing table is about 10% higher in the upper rpm's than mine. Did you adjust your timing to that level thru tuning? Do you have a similiar setup as mine? Just wandering because I want to try the lower idle timing but also may try the higher timing as well.
Edit: Did you look at the closed TPS table for spark timing at idle?
"Spark Advance Closed Throttle Vs RPM" table?
On my bin it is set around 26 degrees and on yours it is set around 22 degrees at 800 RPM's
Whatever you see in that table you need to add initial timing to, so if you have 26 + 6 = 32, mine is 22.1 + 6 = 28.1, and stock is 20 + 6 = 26. Your cam does not need that much timing at idle. Honestly, I took the time to create that file for you. Had you bought from me it's what I would have sent you. Why don't you try it and see if it runs better?
Thanks for the input!
