Fun With A Logic Analyzer
I bought a mid-'80s HP 1651B logic analyzer really cheap on eBay. It's the same vintage as my ECM, so that's fine.
I built an ECM test box that simulates various inputs and has status LEDs so I can monitor the outputs. It's about 80% complete right now. It's interesting to see the IAC calibrate after the ignition is turned off (red/green LEDs). I also have an ALDL connector that I can hook up to my laptop to monitor what's happening.
I bought a connector that plugs into the edge connector on the ECM PC board. That's really convenient because it's a HUGE pain to connect the logic analyzer probes to the microcontroller, especially when it's coated with conformal coating.
All hooked up and running. I'm having a problem with the data display, though. Something is not set up correctly. The program code addresses are OK but the data is garbage. I think maybe it's grabbing the data at the wrong time in the clock cycle.
[ EDIT ] It turned out that I had the wrong EPROM in the ECM. It was an APYP that was in there when I bought the ECM. I took off the label to reprogram it (which in retrospect was a bad idea, given what original EPROMs are going for). Everything's peachy now. [ /EDIT ]
Here it is running off my antique power supply that I built back in the '70s from an article in Popular Electronics magazine:
The cool thing about a logic analyzer is that you can set it up to start recording when it hits a certain address or a variable changes in memory. You can trace the path through the code in real time and see exactly what the ECM is doing and when. Fun stuff.
I used one like this back around 1995. It was too expensive to own so my company rented it. I saved the company a lot of money and trouble when I found a problem using one of these that we had been receiving complaints about for over a year. I never would have found the problem without it.
