TunerCat Vs Moates xtreme
I've been doing some reading and searching here and need to get some clarification about the differences between the TunerCat LT1 packages and the Moates xtreme datalogger setups. It seems that they Will do basically the same thing, at least at the hardware level: interface from a PC to the aldl port to get PCM data. Is there any advantage/disadvantage to one setup over the other? (I've seen the moates setup with different O2 (wideband?) sensors too, but don't know if that's unique)
I'd like to do both. I've got a couple scanners that'll pull data and codes etc, but the post data processing ability is poor( graphing, trending ect). I've got a 94 w a basically stock LT1
