Removal of EGR heat tube.
Old 01-28-2012, 08:21 PM
Marv02
Marv02's Avatar
Default Removal of EGR heat tube.
If I remove the EGR tube that runs from the Exhaust manifold to the intake manifold where it hook to the EGR temp swicth what will happen..
Will this throw a code or what I will keep the EGR temp swicth in place hooked up if needed just caped off.
The reason why I asked this I using a small hard line tube as of now I getting a pulsing ticking sound from the small tube I just want put back on during smog check every 2 years here in Cal.
1986 Vett.
Old 01-28-2012, 08:24 PM
vetteoz
vetteoz's Avatar
Originally Posted by Marv02
Will this throw a code off.
Most likely
still throw a code because no exh gas flowing past switch
Old 01-28-2012, 08:35 PM
Marv02
Marv02's Avatar
Originally Posted by vetteoz
Most likely
Thanks I need to Fab up a larger tube I guess to get rid of that pulsing type ticking sound at idel.
If I put a screwdrive on the Plentum and the other end to my ear thats where the sounds coming from I checked and gone thought the valve trian this is the only thing I could be.
The tube I have on it about half the diameter of the stock EGR tube.
Old 01-28-2012, 11:05 PM
vetteoz
vetteoz's Avatar
Shouldn't be any noise ;
EGR does not operate at idle so no gases are flowing in the crossover pipe ( unless your EGR valve is leaking )
Old 01-28-2012, 11:08 PM
Marv02
Marv02's Avatar
Okay learned something New Thanks.
To Removal of EGR heat tube.
Quick Reply: Removal of EGR heat tube.
