Managed to cloose a hood that's not aligned, now it's stuck
Old 10-26-2011, 02:25 PM
schnyggve
schnyggve's Avatar
Default Managed to cloose a hood that's not aligned, now it's stuck
I have renovated my engine this fall. But when i refitted the hood i forgot to align it. Today when i was going out to break in the new engine i closed the hood. And of course it's stuck on the left side.
The opening mechanism is working fine. I have also tried to pull the wires harder but it wont help. The hood is probably misaligned by almost 1/4" so i guess that the lockpin is probably interfering with the lock housing.
Could really need some good ideas on what to do here. even though i think that the solution in the end is more or less violent
Old 10-26-2011, 02:45 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Have you tried having a helper pull the lever inside while you tug on the corner that is stuck?
Old 10-26-2011, 02:56 PM
85vet
85vet's Avatar
Cruise-In V Veteran
I agree -
Sounds like this will not work -
Try this:
1-Jack car up,
2-remove wheel on stuck side
3-remove plastic wheel housing to access bolts that hold the pin in place.
loosen bolts - hood opens, you should be able to access one or two bolts from the top if the hood pops up a little.
Be patient - this will work!!!
I have been there.
Old 10-26-2011, 04:16 PM
TJM
TJM's Avatar
Originally Posted by 85vet
I agree -
Try this:
1-Jack car up,
I have been there.
me too patience........... a lot of patience.
This what I found ..... after A LOT of patience.
Broken receiver, not good.
TJM
Old 10-26-2011, 06:15 PM
C4orce2
C4orce2's Avatar
I've been there also. Never felt so stupid in my life. Ended up taking it to a friendly dealer with a great body shop. They knew exactly what to do (I apparently was not the first), they took it into their shop and came out 10 minutes later with the hood open and properly adjusted. All at no charge. I think they just liked looking at the car! Not sure how they got it open so fast.
Old 10-28-2011, 02:40 PM
schnyggve
schnyggve's Avatar
Thanks guys
Removed the inner fender and patiens, patiens, more patiens and a 13 wrench cut in half was what did the trick... Tomorrow i'll go out to break in the engine
To Managed to cloose a hood that's not aligned, now it's stuck
Quick Reply: Managed to cloose a hood that's not aligned, now it's stuck
