88 FUEL PUMP removal
Old 10-27-2011, 08:40 PM
Da Mail Man
Da Mail Man's Avatar
Default 88 FUEL PUMP removal
Greetings all - it's been a while!,
........1988 vette...going to replace my fuel pump and remember reading somewhere here about removing/bypassing the "damper/pulsator"(?) on the fuel pump assembly but, was unable to find it in "search".
........Have had my assembly out 2-3 times in the past and there appears to be "that oblong object" down the pipes...If i recall correctly, was it not to "smooth out" the fuel pulsations or "quiet the lines" during fuel delivery?
......How is it removed or bypassed AND, what, if any benefit to removing it?...Symptoms if bad?
Old 10-27-2011, 08:42 PM
JackDidley
JackDidley's Avatar
You can replace it with high pressure fuel line hose. I left mine in place.
Old 10-27-2011, 08:51 PM
Da Mail Man
Thanks for the reply, HOWEVER, were you unable to answer the questions posted? (as follows);
[B] "was it not to "smooth out" the fuel pulsations or "quiet the lines" during fuel delivery?
"How is it removed or bypassed AND, what, if any, benefit to removing it?......Symptoms if bad?
Old 10-27-2011, 09:05 PM
MK 82
MK 82's Avatar
Name, Rank, and serial number!
Old 10-27-2011, 09:12 PM
Da Mail Man
.....ohhhhhhh here we go again!...nothing constructive to add i see....
Old 10-27-2011, 11:30 PM
l98tpi
Max G’s
Support Corvetteforum!
l98tpi's Avatar
ANswer to your question, yes it does reduce vibration and quiets the lines from making a humming noise that could be heard in the car. Another long term benefit is that by smoothing out the vibration of the pump it will extend the life of the pump.
Old 10-28-2011, 07:19 AM
Da Mail Man
......thanks for the reply!
...ahhh, a well thought out, lucid, and well organized reply
.....Is the pulsator/dampener just merely bypassed with a fuel line?....Thanks again.
Old 10-28-2011, 07:36 AM
cgantner5150
cgantner5150's Avatar
Default Hmmmmm....
I believe he did answer that already.
Old 10-28-2011, 11:42 AM
JackDidley
JackDidley's Avatar
Yes, but it was not well thought out or lucid enough.
Old 10-28-2011, 12:38 PM
Da Mail Man
...yup, ya got that right!
Old 10-28-2011, 05:54 PM
MK 82
MK 82's Avatar
I see you haven't lost your touch.
Old 10-28-2011, 05:59 PM
Da Mail Man
.....NOPE!....straight to the point and ABLE TO STAY FOCUSED ON THE QUESTION!
To 88 FUEL PUMP removal
Quick Reply: 88 FUEL PUMP removal
