Diode on the A/C compressor???
Is the side of the diode with the silver band connected to the green or black wires on the compressor connector??? If someone can check that out for me I would appreciate it! Thanks.
Re: Diode on the A/C compressor??? (NUckINg FuTS)
Hey,
Ill check it when I get home tonight. Im tackling the AC nightmare right now too. Can you do me a huge favor and put a voltmeter on the green and black at that plug and let me know how many volts it shows when you turn on the AC? Mine is showing 8 volts only and Im not sure if that is right or not.
Thanks.
Thanks.
I don't know which is which, but the line goes on the supply side. As in one is the supply (pos voltage), the other is the return (lower voltage/ground). I'm not sure which side of the compressor circuit the safety switches are on, so it is difficult to dwscribe from here.
Re: Diode on the A/C compressor??? (VetteNoob)
Hey,
Thanks.
Thanks.
Here's a little schematic I made on MS paint to clarify my question:
I need to know if the band on the diode faces the green/white wire or the black wire.
Just got back in from lunch, forgot I drove the vette eventhough it is my daily driver. :rolleyes: On mine, the band is nearest the black wire.
