Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-18-2010, 02:28 PM   #1
brownc00
CF Senior Member
brownc00's Avatar
Default SD Tuning - Please Confirm My Process
I am about to start tuning my 91 speed density system on my car after I have installed exhaust and intake. After reading a bunch of info over at thirdgen.org, this is what I understand the process to be:
Datalog the car without getting into PE
Analyze the data and get all the non PE data points to 128 BLM by changing the VE tables only.
After that, I'm not sure of the part to tune PE. Any help here would be helpful.
Also, is the prefered method still changing VE tables only (for non PE data points)? Lots of the info at thirdgen is from several years ago and I want to make sure there isn't a new prefered way to tune.
Thanks!
brownc00 is offline   Reply With Quote
Old 03-19-2010, 04:02 PM   #2
bjankuski
CF Senior Member
You are correct, try and get all the non PE BLM's to 128. The PE enrichment will be handles by the commanded AFR when in PE. It should be correct as long as your VE table is correct. The commanded PE table will add whatever percentage of fuel to the base VE table that is entered like 1.14 is 14% more fuel in PE.
bjankuski is offline   Reply With Quote
Old 03-22-2010, 04:31 PM   #3
Rohn
CF Senior Member
Rohn's Avatar
When in PE it will look at the BLM last seen in that cell. If BLM<128(removing fuel-rich) it uses 128. If BLM >128 (adding fuel-lean) it uses actual #. Using 128 in that case would be too lean. On dyno commanded to 12.3 for PE I ran 12.0/1.
Rohn is offline   Reply With Quote
Reload this Page SD Tuning - Please Confirm My Process
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
