Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-15-2010, 04:56 PM   #1
Mile Hi Charlie
Junior Member
Default 1990 Coupe A/T Surging on Deceleration
I am a new guy and this is My first thread.. Need some advice, My car surges slightly on deceleration,mostly in overdrive,idles fine has good acceleration,does not miss. It has new: Injectors,throttle body,fuel pump, and regulator.86,000 miles and had a GM Trans @ 65,000. Local trans shop (trusted) said it might be Idle Control Valve?? It acts like it going in and out of lockup but not as severe.
Mile Hi Charlie is offline   Reply With Quote
Old 03-17-2010, 08:46 PM   #2
SunCr
CF Senior Member
Not that your not feeling something, but without feeling it, difficult to give you a solution. The Idle Air Control Valve does act like a dashpot (when you let off of the gas) to keep it from stalling, but it's seamless (or should be) and capturing data with a Scan is the only way I know to see if it's being commanded to do that. Even if it is, it could be a bit sluggish if the throttle body is gummed up, so you might remove the Coupler from the Air Cleaner and look inside. If it looks like crap, taking it apart and cleaning everything may take care of what you're feeling. Otherwise, and you seem to mention this, it could be a torque convertor that's unlocking and relocking and since you had it at a trans shop they should have scanned it to see what that signal is. Did the put any info on a repair order for you?
SunCr is offline   Reply With Quote
Old 03-18-2010, 12:49 PM   #3
Mile Hi Charlie
Junior Member
Thanks for the reply! The surging is intermittant and it was doing it before I replaced the throttle body,about 3000 miles ago. The trans shop didn't put it on a scanner,but when I take it in for the front pump seal I'll have him do that. It starts right up has a smooth idle and accelerates great and shifts quick. If I do replace Idle Air Control Valve,should I try to find a GM part or aftermarket? Thanks Chuck
Old 03-18-2010, 03:25 PM   #4
SunCr
CF Senior Member
I don't think it matters what you buy, but I've always used the GM (A/C Delco) part. If you do replace it, depress the accelerator slightly before and start it; let it run for 10 seconds; then off for 5 seconds and then restart normally.
Quick IAC test is to start it (helps if it's warmed up). Note RPMS. Turn it off and Restart. RPMS should be higher than what you noted, but return to that speed within a few seconds. If that's right, the IAC usually isn't a problem (and I've replaced more than one that wasn't bad).
I'd suggest you either obtain a Scanner or find some means to Data Log. Much easier to figure things out that way.
Old 03-18-2010, 04:24 PM   #5
Mile Hi Charlie
Junior Member
Okay thanks for your help! I'll test it and see what happens.
Reload this Page 1990 Coupe A/T Surging on Deceleration
Tags
1990, c5, car, corvette, deceleration, surges, surging
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
