Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-14-2010, 09:46 PM   #1
dizwiz24
CF Senior Member
Default What is being controlled by my MAT (manifold air temp) sensor? 93 lt1 ?
What all is being controlled by my MAT sensor?
Spark advance?
Fuel?
I have a blower and am wondering if this is seeing my high intake temps (150F max) and pulling spark advance.
dizwiz24 is offline   Reply With Quote
Old 03-15-2010, 03:19 PM   #2
RC000E
CF Senior Member
RC000E's Avatar
Would've thought someone would answer by now...hmm.
Well, while I haven't specifically tuned Corvettes, I have tuned multiple types of engine management systems...both standalone and reprogrammed oem ecu's. So, its my feeling that the same info should be the case here. That's my disclaimer though just in case.
The IAT (intake air temp) which is the same as whats being discussed here, does allow the ecu to compensate for changes in air density with both parameters being controlled. In all the ecu's and standalones I've tuned, IAT or manifold air temp, has influence over fuel and spark advance.
Now, where it may change is the amount, as some motors tolerate varying conditions differently due to combustion chamber shape, fuel system type, etc. In the systems I've worked with though, your generally look at 0 change at around 100f, then about -3 degrees at 130f, then about -5 or -6 degrees at 160+. Fuel wise, it subtracts maybe 6% at 160F+ and adds a good bit as temps go below freezing.
Knock generally has a big influence over timing, but not sure if you have that or not. Depends on how much timing retard your talking I suppose that may point to whats happening.
RC000E is offline   Reply With Quote
Old 03-15-2010, 10:14 PM   #3
dizwiz24
CF Senior Member
I also see some knock retard too. However, it doesnt account for all the spark retard I see. If I set my timing at 25 degrees and run at WOT, a scan might show I saw 17 degrees timing, and 4 degrees knock retard. What is not accounted for is a remaining 4 degrees of timing retard that comes from somewhere.
Its my belief its coming from my air temp sensor. Im considering relocating this to ambient air temperature and relying upon my tuning to account for this.
Old 03-16-2010, 02:59 AM   #4
RC000E
CF Senior Member
RC000E's Avatar
Sounds pretty possible based on what I've tuned. Hot air is hot air though...less dense=less power and hot air means more knock prone. I don't think just disabling it by accessing it to ambient air is the answer, but it's really gonna come down to the fuel your using and what the motor is gonna tolerate. You may simply remove the mat sensor and gain knock, and then be right back where you started. A better approach would be doing what you can to reduce those air temps.
Old 03-16-2010, 04:23 PM   #5
dizwiz24
CF Senior Member
Yeah, Im working on that. 150 F isnt too bad for FI, but I do have a meth injection kit coming.
I also have the procharger intercooler on there.
My guess is the combination of timing pull from MAT air and knock retard was keeping the engine from detonating.
Especially on the day I did 15 dyno pulls in a row - without incident.
Old 03-16-2010, 04:31 PM   #6
RC000E
CF Senior Member
RC000E's Avatar
Yes, sometimes its ok to leave well enough alone. Getting tunnel vision based on a particular power number always ends bad. 150f isn't bad, but isn't great either, but considering its supercharged....yeah it aint' bad.
Reload this Page What is being controlled by my MAT (manifold air temp) sensor? 93 lt1 ?
Tags
93, air, change, location, lt1, manifold, mat, procharged, relocation, sensor, temp
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
